Question about Dryers
Dryer does not stop - Dryers
  • 6,784 Answers
Hi. this will usually be a defective timer module issue. replacing the timer will fix this issue.
Posted on Jul 21, 2009
  • 374 Answers
as in this case,have you usually set time on timer switch any changes if not,timer switch is defective,timer switch has been short circuited it was malfunction,this timer swtich is where the power source activated when you switch on,it automatically shut off when the time set up reached,if this was short circuited there is continous running or it may not run your dryer.so replace timer switch.hope this help you a lot regards and have a nice day
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
My dryer does not blow hot and will not shut off and no digital reading will display.
Hello Bryan;
My name is Peter. I am a retired field service appliance technician.
So, here are the probable causes:
1.) The blower wheel draws air through the dryer and pushes the air out the vent. If the dryer won't stop, the blower wheel may be plugged up or not be spinning properly, which reduces the air flow. Check to see if the blower wheel is securely fastened to the drive motor shaft. Check the blower hot air discharge manifold for blockage.
2a.) If the dryer won't stop, the gas valve solenoid coils might be defective. Over time these coils will fail, causing the burner to run intermittently. If the dryer is not heating properly it may not stop. Replace the coils as a set.
2.b) The heating element warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element isn't working - which greatly increases the drying time. Check the heating element for continuity.
3.) Dryer sheets and fabric softener can leave a residue on the lint filter, reducing the air flow. If the dryer won't stop, check to be sure air can flow freely, clean the filter as needed.
4.) Although not as common, if the dryer won't stop it may be because the moisture sensor is either defective or shorted
5.) If the dryer won't stop, check the high limit thermostat. If defective, the high limit thermostat can turn off the heat prematurely, lengthening the time it takes to dry a full load. This is not common.
6.) The cycling thermostat regulates the temperature of the air in the dryer. If the dryer won't stop, it may be caused by a defective cycling thermostat turning off the heat too early. This is not common.
7.) The thermistor senses the temperature of the air in the dryer and cycles the heat on and off. If the dryer won't stop, the thermistor may be defective. This is not common.
Nov 16, 2014 | Dryers
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Dryer is occasionally leaving rusty looking smudge marks on clothing.
don't open door (stop dryer) until cool-down and dryer stops. many times the heating element is still hot and when you stop the dryer in the middle of the cycle, the rear of the dryer where the heating element is, will scorch your clothes.
Nov 29, 2009 | Frigidaire FGQ332ES Gas Dryer
Dryer stops in the middle of cycle
The door latch has failed, that's why your dryer stops. When the door opens it stops the drum and turns off. Fix the latch.
Jul 01, 2009 | Maytag PYE2300AY Electric Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Whirlpool dryer
If your dryer stops during its cycle, wait ten minutes and start dryer again. If dryer starts, then the motor was overheating.
Solution, Check for lint blockage around the motor and for possible overloading. If dryer repeatedly stops during its cycle, especially during consecutive loads, replace motor.
Good luck
Aug 10, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
175 people viewed this question
Top Dryers Experts
