Question about Dryers
My filter light is flashing & beeps every 5 min. I have cleaned out the screen checked vent outside it is still blowing warm air
SOURCE: dryer shuts off on own lights blink
Turn off breaker wait an hour turn back on.
Posted on Apr 04, 2008
  • 7 Answers
SOURCE: Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Posted on Oct 25, 2008
  • 999 Answers
SOURCE: Cleaned vents, dryer gets very hot, shuts off w/o drying clothes
Sounds like a faulty operating thermostat. Only way is to test on a electric griddle that you can set the temperature to 150 deg and measure with a ohm meter.
Posted on Jun 08, 2009
SOURCE: LG dlg5988W Gas Dryer - flashing "clean filter" light
i got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
Posted on Jun 16, 2009
  • 7482 Answers
SOURCE: My hoover condenser dryer model
Hi Alan....
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
This is a FREE answer, Please rate me
Posted on Dec 31, 2010
I have a haier air conditioner 5000 n it not blowing cold air its not cooling my house
check thermostat turn off system wait 3 to 5 minutes turn on to cool and turn thermostat to coolest setting if no compressor test thermostat and compressor check filter if dirty and coil iced turn off and lit defrost and change filter if coil warm and unit running compressor internal damage or low freon
Jul 28, 2016 | Haier Heating & Cooling
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your cloths are "hot and damp" you are not getting proper ventilation. Since you cleaned the vent trap let's try a few things to narrow down where this vent restriction is coming from.
  1. Let's pull that vent trap up and start the dryer. Place your hand a few inches in there. Can you feel a light suction of air? (flowing into the dryer)? We will get back to this shortly. Next -
  2. Take the vent hose off the back and turn the dryer on? At this time you should get lots of warm air blowing. If you do not have this and the vent trap did not have any noticeable air flow (into the dryer) then thus far you have a clog between the vent trap and the vent in the back of the dryer. Unplug the dryer and from the rear of the dryer remove the back panel. Should be just a few 5/16 nut with a possible flathead screwdriver indention on them. If you have to do this let's still check the pathway for ventilation to the outside and make sure one did not trigger the other. And if all ventilation to this point is good then -
  3. You have a clogged vent restriction between the duck and the path it takes to outside. For this a duct cleaning service will have to come out and take a high pressured air hose and blow that pathway clear. Now if you have a fairly high powered compressor and can locate the exit for the dryer vent then -
  4. Charge that compressor and put an air gun adapter on it and (wearing eye protection) blow the heck out of it. This will make a huge mess no matter who does it. Make sure it is a good size shop compressor and not one many people carry in their trunk for inflating flat tires (this one will not work) This is how the duct service will do it also.
Mar 20, 2011 | Dryers
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
HEater is heating outside but not blowing warm air thru the vents inside the house. May blow air for 10 mins but then stops. I have the temp. set at 76 degrees but it is 48 degrees in my house right now.
sounds like you may have some restriction in the heater or overtemp sensor is kicking out to soon, clean everything thourghly, check fan and oil bearing, check safety circuits in furnace wiring, refer to owners manual trouble shooting guide
Jan 30, 2010 | Goodman GMS90703BXA Heater
Kenmore elite 62042 says it is done, but, always requires some more time and seems to be progressing towards longer drying times. the clothes are warm but still damp. started 6-12 mos. ago, 5-10 min extra...
Here are a few more things to look at:
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Dec 19, 2009 | Dryers
Model number 110-85866-400. Will not turn on
unplug dryer,you have to take bottom panel off,take out lint filter and then remove the duct that that lint filter goes into,you'll see it on left side when you remove the bottom panel,if it died you could have blown the thermal fuse part number 3392519,you will find this on the right top side of the blower wheel housing it's white and has two wires going to it,pull one wire off and check it with a meter,also go outside and check the flapper were it vents outside,that could be blocked,i blow the vent line out with a leaf blower if it's a long run.if you're having lint problems that should take care of it,also if you have a shop vac,put it on blow and blow off the motor,and you can blow all the dust that' in the back forward so you don't have to remove the drum.hope this helps
Nov 09, 2009 | Kenmore Elite HE4 Electric Dryer
i took the top off checked all the wiring, cleaned the back vents, and the vent tube going outside. I also cleaned the lint screen and gaurd really good, put it all back together. I also unplugged the dryer waited a few minutes and plugged back in. The dryer had a code flashing saying it lost power, I reset the dryer and it has been working great now. Evedently it must be sensitive.
Aug 18, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer keeps blowing the fuse in the fuse bow
check your venting going to the outside it sounds like it is clogged run a load with out the vent connected to the back and see if it works ok if so you need to brush clean the vent to the outside
Jan 21, 2008 | Kenmore 63932 Electric Dryer
Dryers Logo
Top Dryers Experts
