Question about Envision EN9410 19" Flat Panel LCD Monitor
Flashing light nothing else
I have an Envision H22W. One night everything just went out including my computer. My monitor showed a flashing red light. I took my computer in thinking that was the problem and I had a virus on it. I brought it home and hooked it back up but all I could get out of my monitor was the flashing red light and nothing else. I hooked my old 17" monitor back up and it worked great. I really miss my big monitor, does anyone know what is the matter with it? Please, and thank you.
Doesn't sound like a virus. Sounds like a fuse or something else is out. A red light isn't good. If the monitor is ok you get an amber light. I would suggest this monitor is gone. Sorry.
Posted on Jul 21, 2009
How can I find a manual in english?
Check with Envision to obtain the manual.
Jun 30, 2014 | Envision H22W 22" Monitor
Never turns on, power light flashes fast
The flourescent lamps on the sides of the LCD panel is burnt out. If you open the monitor and look at them, I will bed they will be blackend on one end. This is common and you need to find some new ones to replace. They are usually about $15 and plug into the HV little board that drives them. Hope that helps!
Feb 13, 2014 | Envision H22W 22" Monitor
Envision H22W monitor will not turn on, light flashes
check for the source if connected, the vga cable if properly hooked up to the port. if ok then still display wont come on, unplug the monitor and then locate the power supply board of the monitor and look for a bulging electrolytic capacitor which is common problem of lcd monitors.
Sep 07, 2012 | Envision Computers & Internet
Blanks after 2 seconds
The problem is in the inverter board, caused by bad capacitors that sometime bulge at the top indicating it is open. The inverter board powers the back lights behind the screen.
Feb 15, 2011 | Envision H22W 22" Monitor
I have an Envision LCD Monitor, model #H22W. It has a blinking green light but is not working. I have rebooted, unplugged, and plugged back in. Nothing. It won't even turn off. Help.
You need to try it with another PC first, but more likely to be bad caps in the power supply section inside the monitor.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 29, 2010 | Envision H22W 22" Monitor
Was pink at bottom now a black screen. powers on for a second or two then black screen. green power light is on.
Check whether the connector has been properly connected to the computer. Also try to boot the system with safe mode option and you are geeting display, then install the appropriate display drivers will solve your problem.
Also check the DPI setting configured in dispaly properties.
Dec 15, 2009 | Envision H22W 22" Monitor
My Envision H22w Monitor has a green light that is blinking but is not working. IT was working earlier but just went off.
mine just did this tonight. envision has a 3 year warranty and mine was within that so i am rma'ing it.
Sep 29, 2009 | Envision H22W 22" Monitor
Sound
Check if the sound is enabled on your PC then check for wiring that goes to the monitor.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Dec 11, 2007 | Relisys TL 766 Monitor
No Sound on Envision H22W Monitor
The Envision H22W has speaker grilles, but does not include speakers. Note there is no input connector for audio.
The Envision G22LWK does have built in speakers. I think they just used the same mount/frame for both models, but only the G model actually includes the speakers.
Note that the web specs and the manual for the H22W says nothing about speakers.
No doubt this is why the H22W costs appreciably less than the G model.
Dec 09, 2007 | Computers & Internet
Envision EN9410 19" Flat Panel LCD Monitor Logo
345 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
