Question about Miscellaneous
How to repair a torn Charger Power Cord for my Dell laptop.
My power cord was bent and eventually opened up so the inner wires are not connecting well. Is there a way to fix this?
  • 4,300 Answers
It depends where the damage is, on the low voltage side or the high voltage side and how close to a plug?
When a cable is damaged to the extent it is faulty or a safety issue it is best to cut the bad part out and then join together what remains.
Now heat-shrink tubing is so widely available almost every handyman owns a selection as well as a number of soldering irons, it is possible to make good and workman-like repairs to damaged cables and with a great deal of care and patience even make them very close to the plug or the power supply and then use epoxy or a good grade of RTV silicone or polyurethane to make the joint strong again.
By using a sharp blade I have even managed to cut away moulded strain grommets to effect repairs and sometimes used a hacksaw to get inside a power supply in order to replace a cable.
The above applies mostly to the low voltage side. If the mains power cord is damaged it should be replaced if possible. If it isn't possible to replace the mains power cord a variety of small in-line joiners are available.
Posted on Dec 17, 2016
Testimonial: "The tear is only about 15 inches from the laptop insertion site, not near the plug for the wall. I might try to repair it myself with your tips. I never heard of the heat shrink tubing, but it sounds interesting. How can I "connect" the inner wires properly? Any advice on those? Thank you kindly for answering my question so quickly!"
  • Vernon Taylor Dec 18, 2016
    Heat shrink tubing is a flexible plastic sleeve that when is heated will shrink. Most halves the original diameter but more specialised (and expensive) versions will shrink by 3:1 or even 4:1. Commonly coloured black but is available in other colours.
    Using a selection box of common sizes it is possible to insulate cable joints to each conductor with one, two or three layers and then finish the whole with a larger diameter. Enough of the outer sheath of the cable needs to be cut back to allow the heat shrink to be slid well away from the joint before soldering.
    Amazon and ebay will probably supply. CPC Farnell stocks a wide selection of sizes and types. I bought my selection from a local supermarket (Aldi) for just a couple of pounds.
  • Carol Dec 18, 2016
    Thank you Vernon!
    I am going to order this shrink tubing online and give it a try. It sounds interesting. I appreciate your sharing your expertise with me.
When i connect power cord the cords light cuts off/cant power on
sounds like your power supply board, or possibly just the port the charger plugs into if said charger works else where.
Jan 13, 2014 | Dell Inspiron Computers & Internet
Charger tips to small for dell laptop
A Dell Mini net book is a small and very portable laptop. The compact size makes it a good candidate for travel or just simply using around the house. Outdoor aficionados can get the most computing life out of a Dell Mini by finding a way to charge the battery outside. One method works when you are near a building while the other can be used for more remote outdoor locales
Things You'll Need
  • Extension cord
  • Solar laptop charger
  • Dell Mini power adapter
    • 1 Plug an extension cord into an available power outlet. Run the extension cord to where you are outside. Many homes also have exterior outlets. Use an extension cord that is designed for outside use. Plug the Dell Mini power adapter into the extension cord to charge the battery.
    • 2 Purchase a laptop solar charger. Solar chargers are available from several different manufacturers and may come in the form of a roll or be built into a case that closes up for travel. Depending on the charger, you may also need to purchase a Dell Mini power adapter. Some chargers work with a Dell Mini cigarette lighter adapter that is designed to plug into a vehicle's power port.
    • 3 Place the solar laptop charger in a sunny location. Open up the case if the charger is in one and roll it out flat or unfold it to expose all of the solar cells.
    • 4 Connect the Dell Mini power adapter to the power port on the solar charger. Connect the other end to the netbook. The adapter will regulate the charge coming from the solar panel and recharge the battery in the Dell Mini.
  1. Tips & Warnings
  2. Solar chargers offer less power than a wall outlet. They can be used to extend the battery life of a Dell Mini or to recharge the battery when the netbook is off.
  3. Some solar laptop chargers are relatively heavy. Take the weight into consideration if you are going to be backpacking or otherwise carrying it on your person.
Oct 23, 2011 | Computers & Internet
I have a dell inspiron 1545 laptop. Just recently I have been getting a message that the computer does not recognize the power source when I have the AC cord plugged in. We have been using this AC power...
If you are using a Genuine Dell charger, the battery should charge. I don't think its the battery however. My guess would be that there is damage to the inner pin of the charger jack, or possibly damage to the socket where it fits. It could also be down to worn contacts. The charger will power the laptop, as long as there is sufficient contact on the + (inner pin) and a tight enough fit on the outer (-) contact.
If you look closely at the inner pin on the charger, check and see if the inner pin has snapped.
The best check is to obtain or borrow a known good dell charger (aftermarket ones will simply not charge the battery) and see if that resolves the problem, or if you know anyone with the same model, ask them to see if their laptop will charge the battery. That at least will either confirm or deny the fault being with the charger or battery.
More serious is the possibility that the charging circuit has failed. On occasions, the small fuse on the motherboard can fail, or, there is a more deep seated problem on the charging circuit.
Jun 19, 2011 | Dell Inspiron 1545 Notebook
The power inpot is blinking and not connecting
The laptop is either in sleep mode or the battery is low. If the laptop doesn't want to wake up, try unplugging the charger cord, then removing the battery (usually by sliding something on the bottom of the laptop to unhook it). Wait for 30 seconds then put the battery back in, plug in the charger and press the power button.
Mar 05, 2011 | HP ProBook 4510s FM849UT Notebook
Try a different power cord.That may be the problem or the power jack where the cord goes into the laptop.
Jun 29, 2010 | Dell XPS M1330 Notebook
Fire between the end connection power cord and rice cooker
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
May 24, 2010 | Zojirushi NRC-18 10-Cup Rice Cooker
Cannot get past the Welcome screen. Must turn computer on and off about 5 times before user menu comes up. Also getting messages regarding battery and power cord incompatibility. I HAVE ORIGINAL EQUIPMENT!...
The power cord to the system uses a sensing pin (Small wire in center of the plug) to ID the AC adapter. If the pin is broken or bent, then the system cannot ID the Adapter. If the adapter is intact then the issue is the power connection on the motherboard.
In either case, if the system doesn't ID the adapter the battery charger is disabled.
If available, try a different Dell D-Series adapter. If no change, then replace the motherboard.
Jan 27, 2010 | Dell Inspiron 1501 Notebook
The metal plug on my battery power cord is bent. I can plug it in, but have to twist the cord every which way to get it to charge the computer and must be careful not to touch/move it or it goes off again....
You can replace the plug, you can purchase a matching plug from an electronic hobby shop, When you cut off the old plug and solder the new plug onto the lead, MAKE SURE the wires are connect to the right terminals and not shorting against each other.
NOTE - the laptop socket is polarity sensitive, the + and - leads MUST be correctly wired or you will damage the laptop when you plug in the power supply.
If you feel you have not the skills, then I would suggest you get a computer repair shop to repair the power adapter for you.
Dec 24, 2009 | HP Compaq Presario V2000 Notebook
My dell laptop suddenly stopped working without the power cord. power cord needed to be repaired, it had a gash exposing wires. fixed it with electrical tape but it is no longer portable, did i mess the...
It sounds more like the large portability battery has been 'messed' i recommend getting a new power cord. Whist you may have repaired the cabling and it may have appeared to work, the escape circuit for charge may have been broken but it is not required for the laptop to work, but is important when recharging the battery. I recommend getting a new adapter and then if that doesn't work a new large battery also.
Sep 02, 2009 | Dell Latitude D610 Notebook
Dell inspiron 6000 power supply shot...
There are no internal power supplies in laptops. What has most likely happened is as your laptop fell it either landed on the part of the power cord that was sticking out the back/side of the computer or the tension was so great on the plug from it falling that the power supply connector on the motherboard has broken loose from the motherboard. I have seen this happen a lot. This is not a job for an amatuer. It takes someone with knowledge of laptop repair and motherboard repair. In your best case scenarios either the little strip that contains the power button has popped loose and is not making contact (seen this happen in one case) or the power supply adapter (not part of the laptop) has been damaged and torn some wires. In the first case just try to push that power button strip down on the laptop first to see if it will snap back in place. If you can find someone else that has the same adapter you can ask to borrow theirs for a few minutes. Medium case scenario is that it has broken the solder loose and just needs to be resoldered or a new power plug soldered in. Worst case scenario is that it has cracked the motherboard, which will be expensive to fix (it would have to be replaced). Continuing to try and use it in this state (unless it is the best case scenario) will further damage the motherboard as the electricity will start jumping to places it should not go and eventually destroy the motherboard.
Mar 12, 2009 | Dell Inspiron 6000 Notebook
Miscellaneous Logo
22 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
