Question about Cell Phones
My galaxy 7 is turned off as soon it is turned on I did that several time and always turn off again
3 Suggested Answers
SOURCE: TV takes several attempts to turn on.
THIS SOUNDS CRAZY BUT I JUST DID IT ON MINE AND IT WORKS!!!! REMOVE THE LOWER REAR CASE ( ITS THE LARGE BLACK PLASTIC COVER WITH THE VENTS ON SIDE ABOUT 15 SCREWS IT WRAPS AROUND THE LOWER BACK OF TV) USE A HAIRDRYER AND HEAT UP THE LOWER LEFT CORNER OF THE GUTS(AS LOOKING FROM REAR) FOR 5 MINS OR SO THEN TURN IT ON. MAKE SURE YOU UNPLUG UNTILL READY TO TURN ON
Posted on Dec 05, 2009
SOURCE: my galaxy tablet cannot detect
Does the WiFi router have SSID? Did it ever connect to other WiFi Access Point before? If not some say to set the Tab on Static IP and configure the router to allow the Tab's MAC address. Hope it helps.
Posted on Jan 04, 2011
I have not used my tablet for about 3 months . It has always been plugged after every use. I went to turn it on this morning completely dead. It just wont turn on. I have tried a quick fix of power...
Give it some time. charge it, unplug it and start it. Then when it is empty, charge it again unplug and switch on.
repeat this several times,. If it does not change, could be the battery is charged to dead. or a strange spike on the power line killed the tablet.
Mar 15, 2015 | Samsung Galaxy Tab 10.1 - 16GB
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
Jan 31, 2015 | Samsung Galaxy Tab Tablet PC
Printer error 5200
I have had this error several times, I always figure it out, but then when it happens again I forget what I did! So, just happened again tonight after my 4 year old went on a toy copying binge, and this time I bookmarked the fix! 1. Turn off the printer . 2. Press the Stop button for 2 second and hold it. 3. Press the On button, hold it and release the Stop button. 4. Press Stop button 5 times then release together, with the On button. 5. LCD display will blank and now reseting. 6. Computer will detect new hardware just ignore it. 7. Turn off the printer then turn it On. I also removed my cartridges and cleaned the heads after powering it back on. Hope this helps you!
Nov 05, 2013 | Canon PIXMA MX340 Wireless Office...
2001 Bonneville! Several weeks ago, had trouble turning the key in the ignition - sometimes would turn, sometimes wouldn't. Then the Service Engine Soon light came on and the car stalled out a few times...
Service Engine Soon came back on and the car is again stalling ????? Did you have it checked for DTC'S - diagnostic trouble code's ? Service engine soon light on , codes will be present !
Apr 20, 2017 | 2001 Pontiac Bonneville
My samsung phone crashed and won't open again
You can first attempt to do a "soft reboot" by pulling the battery at the same time as the screen is flashing the logo as you stated. (Pulling the battery IE:remove battery with phone in 'ON' state) If this does not solve your problem, a "hard reboot" might be your only other option, (short of bringing it into to a service center location for your cellular provider or sending it into to a service center via postal delivery). To perform a hard reboot on the Samsung Galaxy Pro please follow the proceeding steps as they are listed: Press & Hold The "Power/Lock Key" & "T/3" Key Of The Qwerty Keyboard At The Same Time Until The "Android system recovery " Menu Shows Up. Use The "Volume Key" To Scroll Down & Select "wipe data/factory reset". Press The "Home Key" To Proceed To The Next Confirmation Step. Use The "Volume Key" Again To Scroll Down 7 Times & Select "Yes - delete all user data". Press The "Home Key" To Perform Hard Reset. After 2 Or 3 Seconds It Will Show Data wipe Complete. All User Data Will Be Removed And The Device Will Be Restored To Manufacture Default. Press The "Home Key" To Reboot System Now.
Sep 26, 2012 | Samsung Galaxy Pro B7510 Unlocked...
My galaxy tablet cannot detect our wifi connection. it always says disabled and scanning, obtaining IP address but will not connect. ive turn of/off the unit and entered the passkey several times but still...
Jan 02, 2011 | Samsung Galaxy Tab Tablet PC
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
Ti84 Plus Turns on, and turns off right away.
I had the same problem like yours. First, I reset the RAM and then it no longer turned off right away; but it responded extremely slowly. Second, I tried to install the new OS for it, but unsuccessful until I blowed really hard several times into the round connector. After that, the cursor started blinking. Finally, I downloaded the new OS into it and hoped that the problem never happen again.
You go to http://education.ti.com and follow their procedures to reset the RAM.
Sep 17, 2009 | Texas Instruments TI-84 Plus Silver...
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
