Question about Microwave Ovens
The oven light often stays on with the door closed on model S301T It seems as if the door is not closing all the way to trigger the switch. The light goes off when pressure is applied to the door
    Top Expert:
  • Microwave Ovens Master
  • 36,279 Answers
Defective latch
Posted on Dec 17, 2016
    Prodigy:
    An expert who has answered 500 questions.
  • Microwave Ovens Expert
  • 547 Answers
Door and/or latch assembly is out of adjustment. Some can be adjusted internally. After making any repairs on a door or latch, the oven needs to have a leakage test done.
Drummernick
  • 440 Answers
SOURCE: door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Posted on Feb 10, 2008
Skill Will
  • 53 Answers
SOURCE: Roper Double Wall Oven
hi,
sounds like you may need new hindges, unfortunatly they may not be available any more, it may be time for a new oven.
Posted on Mar 23, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: microwave oven, ge profile model
This is usually caused by either a bad door switch, a loose door switch mount, or bad door hinge alignment.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 20, 2008
localwonder
  • 6784 Answers
SOURCE: microwave not working
HI, this is a faulty control panel. replace asap if possible.
Posted on May 29, 2009
  • 14 Answers
SOURCE: door will not close, light stays on and oven won;t
sounds like a faulty door catch..
Posted on Feb 26, 2010
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
GE Profile XL1800 light out and fan starts running when door is closed
It is not the fault with the fan but the trigger to the fan is shorted. It can be the DOOR SWITCH or the Transistor switch from the board. A fault or error on the processor cannot be ruled out. Clean the main board and reset.
Jan 31, 2013 | GE XL1800 1100 Watts Microwave Oven
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
Microwave refuses to work when START button is pressed. Oven light stays on when door is closed. Control panel seems to be working ok but nothing happens after cooking settings are set and START button...
That's probably a failed door switch or door switch mount.
It's a pretty simple do it yourself fix. See this helpful file on door switches.
You can find handy exploded views and order parts by model number here.
But if your cooktop lights failed recently, you have a damaged control circuit board, which we can usually repair for $39.95. Details are here.
Jan 11, 2011 | Whirlpool MH1150XM Convection/Microwave...
Model jvm1870 when door is closed light does not turn off and automatic fan kicks on even though nothing was selected. Thank you for helping me. Michael
sounds like switch that is triggered when door shuts,is not triggering.check around door opening for switch and push in by hand to see if it is working
Oct 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Cook Light Stays On and Microwave doesn't work
You're close.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel,
we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Dec 20, 2008 | Whirlpool GH7208XR Convection / Microwave...
Door latch not functioning well
the door switch needs adjusting recommend a service tech to do this
Dec 22, 2007 | Whirlpool GH8155XJ Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
