Question about Whirlpool GS460 Gas Kitchen Range
Stove bunners flame are to low?
I have a whirlpool model SF379LEKS stove and I need to know how i can adjust the bunner flame higher?
  • 441 Answers
Take the knob off, insert a small flat head screwdriver into the shaft and turn slowly
Posted on Jul 20, 2009
Does model XFG371LVQ Whirlpool stove have air adjustment for top burners?
Remove the front panel to find where the gas injectors enter the burner tubes you will see they are cut away and have a screw holding an outer ring which is adjustable, open them up more to get more air in .
May 16, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
Burner flame is low
Get a service person to adjust the gas pressure. If done improperly you will be somewhere in the wild blue looking back at what use to be your domicile.
Jan 29, 2014 | Whirlpool NWF30945RS GAS RANGE FOR 220...
Fame to low on my whirlpool stove
You mean the flame is low. You need to clean the burner jet hole orifice and also check if their is a gas pressure regulator which you can adjust the pressure a lithe more higher.
May 10, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
Recently purchased a whirlpool gas range from Lowes "return,discounted aisle" I asked had it been converted to propane and they said yes it had. Wife is overly concerned how do you know they can...
Their is no marking or anything easy to determine that.....however natural gas is lower pressure that propane so if you were using propane and it was set to natural ALL the flames would be huge since it would be operating on the higher pressure while it was set for the lower pressure which would result in a flame thrower from each burner and soot so if the flames are pretty normal size despite the small adjustment for the simmer i believe its set to propane.
GENE
Sep 08, 2011 | Whirlpool SF310PEK Gas Kitchen Range
Knob is turned off but burner light is still on and burner area warm
If this is a glass top cooktop then yes the bunner light will still be on when you turn it off. Also the bunner area will be still be hot. The reason why the light is still on it is telling you that the bunner surfas is still over 95 degrees. Once the bunner area is under the 95 degrees the light will go off. It is a safty warning for people saying that the surface is still hot.
Good Luck and please rate 4 thumbs up for the free answer.
Jul 07, 2010 | GE 30 in. Profile JP350 Electric Cooktop
Just bought a new home. the gas burners don't burn evenly. gas doesn't come out of all the out lets and or some gas flames spike higher than others. how do you correct that?
you must dismantle all the burners and clean them well, also you can adjust the air inlet just at the point the bunners join the jets
Jun 17, 2010 | Maytag CWG3100A Gas Single Oven
We have a gas whirlpol that was converted to
on the gas valve there is a orfice a pin hole you can ajust the size of the orfice by tighting the ajustment a little a 1/4 turn . it is on the valve where the gas gos out to the bunner usualy a 1/2 in open wrench fits on it its made of brass you have to open the top to see it there is also a air ajustment where the bunner fits over the gas valve orfice if the flame is red open it more if its to hot close the air a little make the flame red then turn the gas down tell its blue agin
Oct 20, 2009 | Whirlpool Ovens
Flame on my Whirlpool gas stove burners are too high on low
either turn down the gas knob or turn knobs to lowest setting without going out. That is about your only options
Aug 25, 2009 | Whirlpool SF367 Gas Kitchen Range
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
Jan 10, 2009 | Coleman Propane Grill Stove 9921-700
Whirlpool GS460 Gas Kitchen Range Logo
577 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
