How the child lock will open in top loading machin of i f b
5 Suggested Answers
  • 8 Answers
SOURCE: child lock light stays on - & cant start mc programmes
HI I KNOW IT SOUNDS DAFT BUT HAVE YOU TRIED SWITCHING THE CHILD LOCK OFF? I CANT REMEMBER EXACTLY WHICH BUTTONS IT IS ON YOUR MODEL BUT YOU USUALLY HAVE TO PRESS 2 BUTTONS AT THE SAME TIME (& SOMETIMES HOLDING THEM FOR A COUPLE OF SECONDS) RATHER THAN JUST 1 TO SWITCH THE CHILD LOCK ON/OFF. IF YOU STILL HAVE THE INSTRUCTION MANUAL IT WILL TELL YOU WHICH BUTTONS YOU PRESS TO SWITCH CHILD LOCK ON/OFF HOPE THIS HELPS!
Posted on Jul 30, 2008
barkencoa
  • 3463 Answers
SOURCE: CHILD LOCK STUCK ON
I agree with the initial solution, depress the child lock button for at least 3 seconds.
If it does not clear, then try again.
Good luck.
Please rate my solution.
Thanks.
Posted on Feb 12, 2009
  • 6277 Answers
SOURCE: LG FRONT LOAD WASHER MODEL.
(It COULD be that there is water still inside which is why the machine keeps the door locked. It therefore could be a problem with the drain filter or the drain motor. I'm having to guess!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 07, 2011
richroth
  • 9472 Answers
SOURCE: how to disable child lock
What is the model number of the unit?
Posted on Nov 25, 2012
The electronic door deactivation didn't work on my last load. I opened the door manually but cannot do another load until I deactivate the locking system. Can you help me please?
Believe you have activated child lock.turn off machine at socket then whilst holding the the start button turn on power and hold button in for three to five seconds.if you have a display...look for the key symbol...if it's there then child lock is activated..follow above procedure to cancel lock and key icon should disappear.
Jul 05, 2015 | Miele Washing Machines
Tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
on Dec 10, 2009 | Miele W4840 Front Load Washer
The access door will not open, it is showing the locked symbol in the window
Your problem is either one of the 2 cases below.
1. Door Locked Indicator...'Keyhole' symbol
The 'Keyhole' symbol will illuminate 2 seconds after you have
pressed the 'START/CANCEL' button and will remain lit
throughout the wash programme.
The 'Keyhole' symbol will be flashing at the end of the
programme to indicate that the door is still locked. When the
symbol goes off you will hear a bleep and the door can then
be opened.
2. If the machine has been child locked, deactivate this feature by pressing and holding in the 'child lock' button for 2 seconds.You will hear a beep and the child lock symbol will go out,allowing you to use the machine normally.
Jun 05, 2011 | Hotpoint Ultima WF860 Front Load Washer
How to release child lock in seimens washing machine that is wash and dry D12-52 1200 rpm
Child lock will deactivate only in the original programme that it was activated in. If you have forgotten the orginal programme, try deactivating separately in each programme.
To deactivate child lock press the clock key for 5 seconds.
Nov 07, 2010 | Siemens WFXD8400UC Front Load Washer
Error code on kenmore washer
LG washing machines indicating error code CL may have the child lock activated.
Try holding down the temperature and eco/rapid options together to turn off child lock.
Some LG series use "TEMP and OPTION" at the same time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
CHILD LOCK STUCK ON
Good luck.
Thanks.
Feb 12, 2009 | Hotpoint WMA74 Front Load Washer
Child lock
Try turning the dial back to off, and then try it again.
Make sure the door is shut properly.
Don't interrupt a prog once it has started., if you do , it will start to do funny things.
Nov 20, 2008 | Hotpoint VBSR3100D Top Load Washer
Child lock light stays on - & cant start mc programmes
Jul 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dl code
Press 'pause' & 'reset' together for about 5 seconds. The lock should come off. This is the child lock.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
