Question about Hotpoint Refrigerators
Where is the drip tray on a hotpoint ff200e fridge freezer?
  • 330 Answers
SOURCE: My hotpoint fridge freezer model
check the fan
Posted on Jul 10, 2008
Sea Breeze
  • 4655 Answers
SOURCE: I have a hotpoint refrigerator model CSX24XJ that
There is a leak somewhere in your defrost drain. Most times this is caused by a blockage near the area of the leakage. Below is a link to a very informative way to help you resolve the problem. Thanks.
http://appliancejunk.com/forums/index.php?topic=22.0
Yes your model has 2 drip trays. 1 is below the evaporator inside the freezer and behind the back wall covering the evaporator. The other is below the refrigerator next to the compressor where the condenser fan heats the water and returns it back to the air inside your home. Thanks, Sea Breeze
Posted on Jun 28, 2009
SOURCE: flashing lights super chill super freeze
This is probably because you turned off the fridge at the mains (to defrost??). To stop the flashing lights and to restore normal operation, turn both the Supercool and Superfreeze knobs counterclockwise to "off" and then back to the operating position. Thats all!
Posted on Jul 06, 2009
SOURCE: hotpoint frost free ff200e flashing lights and
Make sure fridge OFF freezer OFF ... then turn mains on. ONLY turn freezer to max, after 30mins put fridge to 1care ... this should overcome the problem of the flashing lights. When both nice and cool turn settings down. it worked for me
Posted on Sep 27, 2009
woodchuck789
  • 4070 Answers
SOURCE: HOT POINT FRIDGE - FREEZER DRIPS WATER
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Posted on Jul 12, 2010
Hotpoint fridge freezer ff200e
did you check your breaker panel water may have gotten to recepticle causing it to trip breaker or damage receptical. did you try using an ext. cord and plugging into a different recepticle. buy the way were you able to find where your water leak came from.
Oct 29, 2013 | Refrigerators
Two amber flashing lights on a hotpoint ff200e fridge freezer
Hello Dawntucker69,
This is a code that the Freezer temperature is too high not cold enough. If this is the case you will want to check and see if the coils on the back and bottom of the fridge are clean and free of dirt as this will cause your freezer to warm up and not work properly. Also listen to the fan in the freezer and make sure that it is running, if it is not running you will need a service tech to come and check your freezer.
Thank you for choosing Fixya.com
Justin
May 08, 2011 | Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Jul 12, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Hotpoint frost free ff200e flashing lights and beeper freezer food defrosting
Jul 05, 2009 | Hotpoint Refrigerators
Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Feb 24, 2009 | Hotpoint Freezers
Refrigerators Logo
126 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
