Question about Refrigerators
Frig is full of water. Noticed that the little hole under the filter was dripping I unlocked and pulled the filter put it back and the dripping seems to have stopped. Problem solved or more serious?
Model #795.77573600 Serial #709KR01155 I had just changed the filter on Thurs
  • 3,182 Answers
Looks like you are on top of this problem
Posted on Dec 17, 2016
I have a side by side whirlpool, water was coming out fine then replaced with new filter and a month went by the water started to come out very slowly I thought the filter may be plugged so put anothe
Cut water supply off to frig disconnect water supply line to frig water inlet valve turn water back on to make sure you are getting good water supplied to water inlet valve some times water cut off gets stopped up. If you are getting good water flow to water inlet valve then check to make water valve is opening up all the way. if not then replace valve.
Oct 27, 2014 | Whirlpool Refrigerators
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
The fridg has a pool of water under the front door that keeps appearing even after we wipe it up. It has suddenly appeared today. It is a Silhouette 442 Frost Free model.
check drip pan under frig.remove ft bottom of frig under door/ck drip tray?full? old frig?-time to buy new one.could be working to hard(age,compressor going bad)will cause frig to sweat.producing water under it.hope this helps.:)
Nov 24, 2009 | Lands Phones
IWater does not dispense.
Good day,
The hum is normal. That's the water valve in the rear of the machine being activated.
Lots of plumbing to be checked.
Water line starts at the dispensing outlet in the door, and runs thru the door to the bottom of the hinged side.
From there it goes to the filter,
'From there it travels under the machine into the cooling reservoir mounted back of the fresh food section behind the crispers.
From there it travels back out and runs to the water solenoid mounted on the back rear of the machine.
One of these lines or their fittings has failed.
It's a look-see repair.
Also, there is a remote chance the water line running inside the freezer door froze, causing this problem, and would require the machine be shut down (unplugged) and the door be allowed to defrost completely.
Nov 16, 2009 | KitchenAid Refrigerators
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water collects on the bottom of the freezer i own a frigidaire s/s frs26zrg, water also comes out onto the floor on the left side. Doesn't look like its coming from inside of the frig saw it once as...
UNPLUG REFRIG. Empty freezer. Wipe interior dry. Check defrost hole at back of freezer & clean out as much as you can. Pull out refrig. Take off back cardboard cover. Lie on floor and look in. Bottom right under the defrost hole there is a black rubber hose that empties into a drip tray. Black mold grows inside and plugs it up. Get a thin aquarium brush and push it up the tube to clear it. Put the tube back into the tray to drain. Put everything back. Plug it in. Fixed.
Aug 04, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
