Question about Cell Phones
How do i reset a mp3 4gb eclipse
All of my music i had is not on there now what should i do
For some reason, can't sync music to my Eclipse from my computer.
You don't need to sync with Eclipse. When you have it connected to your computer as Removable Disk, you can copy your music files from your computer to the Music folder (I believe so it is called)
Jul 01, 2015 | Eclipse Audio Players & Recorders
I try to sync my music and all my eclipse says is USB connected. what am I doing wrong/
Check if your files appear in computer as Removable Disk. Copy/pate or move your music to MUSIC folder of Eclipse
Apr 24, 2015 | Eclipse 180g2 4gb mp3 music/vid
How do I download songs on my eclipse mp3 player
Things You'll Need
Microsoft Windows 7 computer with an open USB port and iMesh installed
USB cable compatible with Eclipse MP3 players
Instructions
  • 1 Plug a USB cable into the Eclipse MP3 player. Plug the other end of the USB cable into an open port on the Windows 7 computericon1.png.
  • 2 Click the "Start" button on the Windows 7 desktop taskbar and click "Computer" in the menu that appears. Click the "Music" item located in the left pane of the "Computer" window that appears. Double-click on the "iMesh" folder. For Windows 7, XP and Vista. Recommended. Download Now.
  • 3 Click the "Start" button on the Windows 7 taskbar and click "Computer" and then double-click on the "Removable disk" icon that represents the Eclipse MP3 player device. A window will appear displaying the contents of the Eclipse MP3 player storageicon1.png area.
  • 4 Right-click on a music file in the "iMesh" directory that has the "mp3" suffix, and click "Copy" in the menu that appears.
  • 5 Right-click on empty space in the "Removable disk" window and click "Paste" to copy the music file to the Eclipse MP3 player device. Repeat for each file you wish to download to the Eclipse MP3 player.
    To copy multiple music files at one time to the Eclipse MP3 player, press and hold the "Shift" key on the keyboard. Click once on each file you wish to copy. Right-click on one of the highlighted MP3 music files and click "Copy" in the menu that appears. Right-click on empty space in the Eclipse "Removable disk" window and click "Paste."
Oct 21, 2014 | Audio Players & Recorders
Eclipse 180g2 mp3 video player
Hello. Try to reset it to factory settings first and see how it reacts. Good Luck.
May 30, 2014 | Eclipse 180G2 MP3 Music & Video Player
What do I do to Eclipse fix mp3 when it diplays "Disk Error!" upon attempting to play music?
Presumably the error is caused by a hard disk drive? In which case the hard disk will need to be checked. If there are options to do this use them. Otherwise the drive might need to be replaced.
If you bypassed the normal way of putting music onto the drive, then it might have corrupted the drive.
If there is an option to reformat the drive that might work. Or if there is a factory reset, that might correct it.
If you have music stored on the drive, which is not found anywhere else, then I think it will have been lost for good.
May 27, 2017 | Eclipse Audio Players & Recorders
Does the eclipse 180g2 4gb mp3 player have a reset button or not
Unfortunately there is no way to reset it. This unit is notorious for multiple problems. Far far more unsatisfied users than satisfied
Feb 06, 2013 | Eclipse 180 G2 RD 180G2 4GB MP3 MUSIC &...
I have had some issues with my 4 gb eclipse
My mp3 has a messed up screen, I charged it and the screen is fuzzy. I have tried to reset it several times and it does the same thing, you can't see anything on the screen.
Oct 28, 2012 | Eclipse T2810C 4GB 4GB MP3 MUSIC & VIDEO...
HAVE A TECNIKA MP3,4GB PLAYER FROM TESCO,CAN DOWNLOAD MUSIC,BUT WILL NOT PLAY,READS ON MP3 PLAYER"HDS ERROR,CLEAR DRMHDS ? HELP
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player. For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Jul 18, 2011 | Audio Players & Recorders
How do i reset an ECLIPSE MP3 player
Unfortunately there is no way to reset it. This unit is notorious for multiple problems. Far far more unsatisfied users than satisfied.
Mar 08, 2011 | Mach Speed Eclipse 180 MP3 Player
It stops at the eclipse logo and wont let me listen to my music
you can try to reset the device by pressing the play/pause button for 30 seconds.
Mar 06, 2011 | Mach Speed Eclipse 180SL 4GB MP4 ...
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
