Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My cabrio washing machine keep showing F1 error when you
Select all three cycles of wash.
  • 15,935 Answers
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
F1(F68)-Pressure Signal Out-of-Range
I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Cabario. I keep getting an error code of F1. I hit cancel and then start several times and it resets itself and continues. The same thing happens when it is about to start the rinse...
Hi
Thanks for using FixYa. Error F1 indicates primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How to fix my Whirlpool Cabrio washing machine F1 code that keeps popping up whenever I turn on the washing machine.
Hello, error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. To remove and replace the control you’ll have to unplug the washer and then remove three screws from the rear of the console assembly. Pull console towards front of washer to hinge open and/or remove console. Then remove the one screw holding the machine/motor control assembly to the console tray and two plastic legs on the rear of the machine/motor control assembly that fit into the console tray.
Thanks
Jun 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I get error F1 every time I start and before the rinse cycle. I will change cycles, change settings within cycle menus, it tales at least three attempts of shutting it off and restarting it. Now it will...
here's the part # W10189966. I guess whirlpool had a recall on the units and revised the control boards. might want to call whirlpool on that. Good luck :)
Jul 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio agi stops after wash cycle
you may need a new timer. yes have it looked at.
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
Apr 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
F1 error code
replace machine control bd under console
Oct 30, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
231 people viewed this question
Dan Webster
Dan Webster
Sal De
