Question about Philips Irons
Philips 1900 series steam iron is shocking when i touch soleplate and wet cloth
SOURCE: philips careeza soleplate cleaning
Change your iron
Posted on Oct 03, 2007
satscoop
  • 59 Answers
SOURCE: Brown spots coming from steam iron
you can mix 50% water with 50% vinager let it set in the iron overnight then turn it on and let the steam run out.What happens is the inside of the iron where the water is had corroded or rusted or has lime deposits.the vinager will break this loose overnight.also after you let the iron steam out all the mixture,flush the iron 4 to 5 times and start using fresh water from a store bought gallon.your tap water is probably full of iron.
Posted on Nov 15, 2007
geokohler
  • 304 Answers
Fill with 50/50 water vinegar solution. Get it good and hot and let it sit for two hours. Rinse and repeat if necessary. Buy a gallon of water from the market and use that from now on. This will fix your problem. The Iron is concentrating the iron in you water and this is what is causing the brown spots. Hope you find this helpful. If you do please take the time to rate it fixya and maybe I will keep helping people for free.
George
Posted on Jul 24, 2008
SOURCE: Problem with Philips Azur Precise 4340 Iron
i had the same problem and the Philips hekp site was no use. I turned my iron off until it was completely cooled down then switched it back on again, with the steam number turned to 5 and the heat on max. as soon as the ready light went off, i put my iron in the horizontal position and shook it back and forth (quite vigorously) and it seemed to have dont the trick!
Posted on Aug 28, 2008
  • 108 Answers
SOURCE: The iron is dripping water when in the steam mode.
try less water and distilled water not tap water.
Posted on Dec 22, 2009
The bottom of my rowenta focus has a burnt grainy film on it. How do I clean it and prevent it from happening again. I've only used it approx 4 times but it is over a year old.
Rowenta FOCUS STEAM IRON DZ5164 DZ5164U1 user manuals
will give their specific instructions.
Rowenta has a kit, including a paste cleaner for iron soleplates, available from Amazon.
Home made cleaners include a paste of baking soda and vinegar. Rub on, let sit, and wipe with a wet cloth. (Some add a drop or two of dawn dishwashing liquid)
Another home made cleaner is the Mr. Clean Magic eraser, thoroughly wet, and rubbed over the soleplate.
Make sure to wipe the soleplate with a clean wet cloth at the end to remove cleaning residue.
Clean your iron's soleplate while the iron is cold, and don't use something scratchy like a steel wool pad, to avoid scratching the surface.
Aug 11, 2017 | Rowenta Irons
Philips 6104 duble speed
follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 29, 2013 | Philips HI-296 Iron
Tefal steam generator iron
follow this steps and fix it. God bless you
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Nov 24, 2013 | Irons
How to open a steam iron severin
follow this principle.God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
  1. Unplug the iron.
  1. Unplug the iron.
Jul 20, 2013 | Severin Steam Iron, 2500 Watt, White...
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
Cleaning Carezza soleplate of iron
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaning a Steam Iron Soleplate
heatman101
Jul 06, 2010 | Philips GC 8220 Iron
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
May 05, 2009 | Philips HI-296 Iron
Irons Logo
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
