divide both dimension by 12 to get feet the multiply those feet measurements to get square feet or multiply the inch dimension to get square inches and then 1 sq " =.0069 sq ft that is 76 X 69 =5244 sq "=36.416 sq ft
If you measure the height, width and depth you can calculate the volume. You multiple the height by depth by width. Make sure you use the same units for each measurement. For example if you want the volume in cubic feet, make sure all measurements are in feet. If the height is 5 feet 8 inches, you need to convert this to feet, which would be 5.67 feet, likewise for the other two measurements. It wont be exact because there will be bits sticking out but will be near enough. Make sure you also calculate the volume of the door space as that is included in the volume.
linear feet is a length measurement as to how long it is --example : a piece of timber 20 feet long is 20 linear feet
the measurements you have provided will give a cubic feet measurements which is a volume measurement. so convert all the dimensions to feet , multiply all together and that will be your volume
Measure the length and width of each wall, and then add up the resulting answers. So, if a wall is 9' tall and 12' wide, it is 108 sq feet. If another wall is 9' tall and 11' wide, it is 99 square feet. Your total would now be 99 + 108 or 207 square feet.
If you are doing it in feet and inches, you have to covert the inches to feet by dividing them by 12, since there are 12' in a foot. So with 3", divide 3 by 12 and get 0.25.
Normally refrigerators have stickers inside that state the cubic feet. If that's missing you must measure the width X depth X height to get cubic feet. WxDxH= cubic feet.
Female Ideal Weight - Above Average Height
The average height of a woman in the US is 5-foot-4. When considering the weight and height ratio, a 5-foot-5 woman should weigh between 113 and 138, 5-foot-6 between 117 and 143 and 5-foot-7 between 122 and 149. The weight and height ratios continue to increase at approximately 4.5 pounds at the low end and 5.5 pounds at the high end of the range, per inch of height. A 6-foot-tall woman's ideal weight range is 144 to 176 pounds and a 7-foot-tall woman's range is 198 to 242 pounds.
Male Ideal Weight -- Under 6 Feet Tall
Men have an ideal weight range similar to that of women, but their weights are higher per inch. A man who is 5 feet 11 inches tall has an ideal weight range of 155 to 189 pounds, which is significantly higher than the 140- to 171-pound range for women. Men under 6 feet tall can determine their ideal weight without consulting a height-to-weight ratio table by starting at 5-foot-11 and a weight of 155 to 189 pounds. Simply subtract 5 to 6 pounds per inch from the low of 155 pounds, and 6 to 7 pounds per inch from the high of 189 pounds. Thus, a 5-foot-5 man has a range of 122 to 150 pounds and a 5-foot-tall man has an ideal weight range between 95 and 117 pounds. Are There Ideal Weight and Height Ratios LIVESTRONG COM
I can't locate your particular model online, but you can figure the cubic feet yourself
Empty your refrigerator /or freezer to facilitate easier measuring. Measure the height, width and depth of the refrigerator's interior.
Measure in inches, and write them down.
Multiply the measurements this way: H (height) x W (width) x D (depth).
This is the interior capacity of your refrigerator in inches. To convert the number to feet, divide the number by 1,728. This converts cubic inches to cubic feet.
I hope this helps you. Thank you for using FixYa. Your rating of this answer is appreciated.
