Question about Ovens
Rational oven cmp model have 2fan probelam dowan fan not working we change moter same what actval case
Why combi oven error code 32
If it is a Rational CM or CMP gas oven, then there is a problem with the ignition module.
Feb 03, 2017 | Combi Ovens
Rational SCC 202 service 34-6
34-6 is a service code associated with both the upper and lower oven fans not operating. Check the fan motors. there is a green LED. they should be on steady. If they are blinking, watch and count how many times it blinks before starting over. that is the error code associated with the fan motor. If there is no LED lit, then the fan power supply has failed. The fan failure is a hexadecimal code. "2" is the master fan failure, "4" is the slave fan. "6" is both fans. data to and from the fans is via the I/O PCB. There is a data cable from the operator pcb to the I/O PCB, then on to the fans. The problem can lie anywhere. Fans, PCB's, or data connections.
Jul 09, 2013 | Ovens
My rational selfcooking center says service34-2- no function please help
You really need a specialist repairer to resolve this but this generally relates to a main fan motor defect or a failure elsewhere in the bus circuit.
Sep 03, 2011 | Ovens
Rational combi oven service manual
Alarm beeping control board not working
Apr 28, 2010 | Ovens
Will not ignite when turned on hear no sparking
1check if gas is conected and gas present
2press all the reset buttons at side
3aheck that the blower fan in control chamber is is not bloked eg setting the ventilation hole on side of blower moter
4check that the presure tube between blower moter and pressure switch is not blocked by dirt.
5 then try putting on again
Apr 23, 2010 | Lincoln Conveyor Oven - 1133-000-A
Error " service 34 -6-
check polarity means you have the live and neutral to the oven swapped over, you need to change the live and neutral. service 34-6 means there is a communication problem with both the fan motors but this will probably be cured when you swap the live and neutral
Mar 01, 2009 | Bakers Pride CO11-G2 Gas Double Oven
Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
Oven not heating KitchenAid KERC506HWH3
Built-in ovens have a thermal fuse mounted in the back of the oven preventing the bake and broil from operating. In some cases this fuse will open after a self clean operation. In some models, the cooling fan turns off too soon, causing an overtemperature condition that may also cause the fuse to open. You will have to remove the oven and take off the back panel to gain access to this device.
May 25, 2008 | Frigidaire PLEB30T8A Electric Double Oven
Oven no heat
check fan element hasnt blown remove back plate in oven after switching off from mains of course and remove the retaining screws and you will see a fan and around that the element it will be obvious to see if its blown as there will be a hole on the casing if so replace and viola.
Jan 16, 2008 | Neff B1641 Single circotherm super...
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
