Question about Kodak Office Equipment & Supplies
Kodak carousel 550H projector won't advance to the next picture.
SOURCE: Kodak Carousel 760H wont advance or reverse
Yeah. I like the $15 fix better. Go to Ebay and search for "Kodak Carousel Projector Advance Repair Kit". Before you purchase you can diagnose, and it comes with detailed instructions. The same guy also has a kits for other common problems, as well as the "tune up kit". Or you can buy the Solenoid Link, directly and try it without detailed instructions.
Posted on May 22, 2009
projdoc
  • 2236 Answers
SOURCE: My Kodak 760H Carousel projector does not advance
do you hear any sounds when you press the button? if not, the button may be malfunctioning. if it doesn't make a sound or movement in reverse either, there is a bad connection between the controls and the solenoids. if it does try to advance and not move the carousel, it's a mechanical problem in the mechanism. usually due to the grease getting sticky from heat and age. take it in for a good cleaning and an adjustment. there are a few cams in there that wear out after a while, too.
Posted on Nov 13, 2009
  • 412 Answers
SOURCE: problems with using a 140 carousel on a Kodak 4600
There is nothing wrong with your slide trays. Your projector needs an adjustment to the cycle contact assembly. The constant cycle mode is a dead-giveaway. You need to take the projector to an Authorized Repair Dealer for this adjustment. Should be relatively quick - - it takes longer to get the case apart than to make the repair!
Posted on Nov 04, 2010
  • 412 Answers
SOURCE: I just purchased an older Kodak slide projector
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Posted on Dec 30, 2010
  • 412 Answers
You have jammed the slide change mechanism. Turn the projector off. Remove the tray using the emergency release slot in the center hub of the projector. Turn the projector on and cycle it a few times in reverse, then in forward. That usually clears a mechanism jam.
Posted on Jan 04, 2011
My Kodak Carousel 750H slide projector will not forward next slide or reverse
Your projector problem sounds like a broken cycle solenoid LINK. The LINK will be available from: www.micro-tools.com
They should have installation instructions, as well. See the attached picture for more details. Good Luck!! Jim
Dec 09, 2013 | Kodak Office Equipment & Supplies
Kodak 850 Carousel Projector tray won't advance
The Carousel 850 is 40-45 years old. The symptoms you describe indicate the timing is off. Timing is an "adjust & test"..... try a SMALL adjustment and then test it.... adjust again & test again. Repeat until you get smooth tray action. See the attached illustration:
May 16, 2013 | Kodak CAROUSEL 850 KODAK
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
My kodak carousel 5600 slide projector wont stop advancing unless i unplug it
You are experiencing a fairly common problem called continuous cycling. It is caused by use or mis-adjustment.
If you feel comfortable with a electro-mechanical adjustment, take a look at the attached picture for the correct alignment of the cycle contacts. The positioning is critical for correct operation.
Turn the projector upside down (unplugged), and remove the bottom screws. Then carefully remove the bottom cover. The cycle contact assembly will be in the center of the projector.
If you need help, contact a authorized repair dealer. Good Luck!!
Jun 21, 2011 | Kodak Carousel 5600 Slide Projector
Carousel on my projector does not advance not sure if I have the carousel on right or whats going on.
Please re-post this problem with the specific model name/number of the KODAK projector. The model (and age) of your projector will determine what is wrong.
Nov 08, 2010 | Kodak Office Equipment & Supplies
The advance and reverse button is frozen. the auto focus is also frozen my kodak carousel custom 840H projector is 35 years old. should I just buy new?
You may have trouble buying new. Kodak stopped manufacturing slide projectors in 2004. There are qualified repair dealers that you can send your projector to & get it fixed. What you describe is a pretty common problem with the Carousel Custom line as they age...
Sep 27, 2010 | Kodak Office Equipment & Supplies
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
Need to make it advance automatically
Sure! Not only did Kodak sell an external automatic timer that plugs into the remote socket, a number of other companies had them as well. If you can't find one searching online for "Kodak slide projector plug-in timer", try: www.micro-tools.com Good Luck !
May 12, 2009 | Kodak Carousel 4600 Slide Projector
Will not advance although nothing is stuck in the machine.
Sounds like what your projector needs is a cycle contact adjustment.
Remove the slide tray & lamp module. Unplug the projector. Turn the projector upside down to remove the bottom cover (6 - T-15 TORX screws). Pry the bottom cover off from the handle side (Be careful!! The power cord is physically secured to the bottom cover!). I have attached an illustration for reference. Near the center of the projector you will find a contact as shown in the illustration. That contact needs to be in the position shown on the pad. You will have to slightly bend the "J"-shaped wire carefully(!!). Then plug the projector in, turn it on & cycle it a few times. The 2 contacts should look like the illustration when at rest. If they don't look like that, unplug the projector, "tweak" the contact wire a little bit more, plug the projector in & try again. This adjustment can take a factory-trained repair tech several bends to get it right (without breaking off the wire!!). Repeat until you are successful! jauburn_8.jpg
Apr 19, 2009 | Kodak Carousel 4400 Slide Projector
Nov 23, 2008 | Kodak Carousel 4600 Slide Projector
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
