Question about Samsung Refrigerators
Electrolux model E126SS30JS3/side by side refrigerator/ my ice maker is not making ice and no water comes out of door water/ice access point.
SOURCE: ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
Posted on Jul 05, 2008
  • 12 Answers
SOURCE: Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Posted on Dec 01, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Posted on Apr 27, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
Ice maker stopped working water coming out of front of door. what to do?
There are two sides to a water control valve Cindy. One side for the dispenser and one side for the ice maker. Feel inside the ice maker slots for any remaining ice cubes. If the ice maker has no ice fill with tap water and if after the water freezes and drops the ice into the ice container and then does not refill with water the problem points to the dual water control valve. If the ice just sits in the ice maker and does nothing then this points to a defective ice maker. What is the model number of the refrigerator?
APPLIANCE 911
Dec 06, 2015 | Refrigerators
Electrolux Ref. 3yrs old. ice maker will not make ice, water dispencer will work. I have replaced filter.Ice maker goes through the motion but, no water. can you help me?
either your fill tube is clogged or the water valve in the back of the refer has failed. Go to the back of the unit, if my memory is correct the yellow hose is for the ice maker, at the water valve disconnect the 1/4 hose from the valve to the ice maker only, place valve in a bowl, cycle ice maker. If you get water, fill tube is obstructed, if not water the valve has failed and needs to be replaced.
Good Luck
Oct 28, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
I have an electrolux double door freezer on the bottom. the ice maker leakes water from the back and water drips from the dispenser inthe front. the cubs in the tray clump together does anyone help me...
That is simply your dual water control valve found on the back of most refrigerators. If I had your model number I would be able to point out the part number and location. Here is what happens. The water valve begins to slowly leak water that comes to the ice maker when not needed. It moves slow enough that it begins to freeze solid inside the fill tube to ice maker and when the ice maker calls for water there is a big chunk of ice in the way and the water goes everywhere but where it should. Here is a short clip with lots of info, Please Rate and Thanks, Sea Breeze
Apr 28, 2011 | Electrolux Refrigerators
Ice mker not working
ok make sure u have water coming into back of ref. make sure your ice maker wire is down in on position. chech and see if water in ice maker.. u have to have water. u have a solenoid that allows water into ice maker. check this out then let me know what u find then i will walk u tru what else to check..ok i hope this helps u..
Feb 12, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Ice maker getting water but no ice being made checked lines not bend water running up lines and have been flushed water dispenser working great
is there a overfill bar on the side of the ice maker where the ice bowl is if so make sure that it is in the down position
Jan 23, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Power to the ice maker/water dispenser seemed to have shut off. Ice maker is still making ice, but the dispenser is not working. Is there a fuse or something?
frigidare 36' side by side. makes ice, nothing comes out of the door dispenser, auger truns. prior to this it would only give crushed ice even if set on cubes
Dec 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker not putting out water just hooked up ice maker kit
Are you getting ice? It seems like my brand-new electrolux does not produce cold water unless it is producing ice as well. We had to adjust the auger in the ice tray to start getting ice ... seems like our water is now getting colder.
Jul 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
24 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
