Question about Pool & Spa
Maax spa,keeps overheating and the two speed pump will not turn off?
SOURCE: High speed spa pump shuts off
The motor may have a thermal cutoff if the motor draws too much current. Do you have a sufficient large gauge circuit supplying the motore? If not the actual voltage at the motor may drop, causing it to draw more current to make up for the loss of voltage, thereby tripping the motor's protective breaker. I assume the motor will start again after serveral minutes of cooling down.
Curtis
Posted on Apr 19, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: the spa won't shut off. It keeps overheating
Check the filtration cycle. I have seen several hot tubs over the years where the owners have accidentally changed the filter cylce duration without realising.
If the filter cycle duration is set too long it may/will overheat.
It's also possible that you may also have a problem with the PCB. This would need to be checked by a spa technician who knows the system well.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 08, 2010
john224
  • 1378 Answers
SOURCE: i have a elevated spa
Based on your description I'd suggest an electronic valve controller and panel to set the valve to the desired flow based on pump usage. If you do not have a control system with electronic valves you are likely in for some sticker shock but it would be the only way to automate what you are describing.
John
Posted on Oct 23, 2010
  • 111 Answers
SOURCE: I have a maax spa, the pump and air lights are flashing, any ideas?
Maax, use a lot of proprietary components calling them is usually best.
But first there are two things which will shut a spa down like this are the main GFCI breaker or the Hi-Limit switch.
Reset or replace.
Posted on Jan 26, 2012
aj53011
  • 6 Answers
SOURCE: Maax Spa Question
They should have an online manual of the website. Look that up or call costumer service
Posted on Apr 28, 2012
Water sensor needs to be replaced. 8 yr old unit. Maax doesn't carry old parts unavailable HELP PLEASE!
Parts for Maax Spas‎
www.spaguts.com/
(714) 764-0014
Pumps, packs, heaters, controls,
ozonators for Maax hot tubs.
# 27 Hot Tub Heater Replacement for 240 volt hot tubs ...
? 6:27
https://www.youtube.com/watch?v=xNWjM8c_b-8
Oct 10, 2011 - Uploaded by softcellelectrical
27 How to replace an in line or flow through heater for an above ground ... I just changed out the water in my spa when I discovered the heater element ... Is there a hose that should fit on it? ... I figure it will run similar to a whirlpool setup. ... tests on the unit...but, it sounds like 1. your sensors may be DC and
Jan 18, 2016 | Maax Home
Spa error code
www.maaxspa.com.au/why-maax-spa/support
Jun 11, 2014 | Pool & Spa
Spa overheats because no circulation during heating process
As I'm sure you know the low speed is the filtration & heating cycle.
If you've checked the terminals on the board and on the pump & there's nothing wrong. Use a voltmeter to test if each leg is getting the right voltage. If not its likely the motor is bad.
Nov 11, 2012 | Pool & Spa
A O smith part 7-177896 pool pump screaming
bad motor replace whole unit if overheating ruining rest of pump
Jul 26, 2012 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
How to replac bearings in century pool & spa motor
if bearings are bad motor overheating and ruining seals replace whole unit less hassle
May 10, 2012 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Reset or replace.
Jan 15, 2012 | Maax Home
Pool & Spa Logo
50 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
