Question about HP PSC 2510 All-In-One InkJet Printer
Hp printer error code 905EooFF It will print pictures but not letters, etc
Ho desk jet 2050 J2510 ,window 7 , been ok for years now playing up for no reason, tried to uninstall and reinstall, even after restart, thanks for any help in advance,
  • 99 Answers
SOURCE: error code 1517--remove and check cartridge
Solution Follow the steps below until the above issue is resolved. All of the following steps may not be necessary to resolve the issue. Step one: Clear any paper or carriage path obstructions Right-click the link below to open a new browser window with specific instructions about how to clear paper jams. When you have completed paper jam removal instructions, return to this point in these instructions to continue resolving a carriage stall. Click here for information on resolving paper jams (c00107909). (in English). Moving the carriage
  1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
  2. Without turning off the product, unplug the power cord from the back of the all-in-one. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
  3. Looking in through either the print cartridge access door or the output paper tray, verify that the print cartridges are locked into the carriage and have not come loose. Also verify that there are no obstructions under or around the carriage to block it from moving.
  4. Verify that the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
  5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
  6. Press the On button to turn on the product.
  7. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next step.
Step two: Ensure correct installation of the front panel overlay If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, ensure correct installation of the front panel overlay by following the instructions below. If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to re-install the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
NOTE: 12If the front panel overlay is already installed, proceed to the next step.
  1. Insert the two tabs of the bezel into the top slots on the unit. Figure 1: Inserting the tabs c00303994.gif
  2. Tilt the bezel down and press firmly. Verify that the tabs lock into position and that the cover is even with the edges of the unit. Figure 2: Locking the tabs c00303995.gif
  3. Try the print job again to see if this step resolved the issue.
Step three: Plug the product directly into a wall outlet Verify that the product is properly connected to a suitable power source by following the instructions below.
  1. Verify that the computer and the all-in-one product have a three-prong power plug.
  2. Unplug the power cable from the back of the all-in-one.
  3. Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  4. Plug the power cable into the back of the all-in-one.
  5. Try the print job again to see if this step resolved the issue.
      NOTE: If the product prints when plugged directly into a wall outlet while unplugged from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
Posted on Feb 09, 2008
michael464
  • 8 Answers
SOURCE: Incompatible ink cartridge(s) ERROR on HP 4230 All-in-on printer
Try uninstalling and reinstalling the drivers. This can be done by going to the Add and Remove programs, this is located under the Control Panel. You may have to reboot and I would recommend that you do. This will clear out the Print Spooler. The Print Spooler is located under the C Drive and may get corrupted. You can find information about this in Google. Look for repairing spooler on the OS that you are using.
Posted on Dec 31, 2008
pagebor
  • 2785 Answers
SOURCE: Continous Red light blinking on the printer causing it not to print
plz check the ink cartridge status
Posted on Apr 21, 2009
  • 100 Answers
SOURCE: I have HP deskjet F4100 All in one printer does not print
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867129&cc=us&lc=en&dlc=en
Posted on Mar 17, 2010
Daniel S
  • 4323 Answers
SOURCE: Try to print but: get General Printer error 0x61000f6
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Posted on Jun 22, 2010
Testimonial: "Thank you very much for the information. very helpful. I am sure this information will help other people as well. Thanks again. "
What printer should I buy which is lowest cost to operate, lowest cost for ink
My personal preference is Epson. There are loads of deals out there. Best bet is to go into somewhere like Staples and have a look at them and then google for the best price. Mine, now over 2 years old so not available any more. It is wireless, has its own address so I can print from a phone or pc whilst out, and photocopies, prints and scans into a pc. It does all I ever need and the best part is that you can use non Epson inks saving a fortune on refills.
It sounds like I work for Epson. I don't I just prefer them.
Nov 08, 2015 | Office Equipment & Supplies
My printer is hp deskjet 2050 j510 It's always printing page including error code 00000000 And error code 0299c2ed
My printer is Hp Deskjet 2050 J510 Series. It prints well the first line but the last lines, it does not print. The after a while it send a message like this.
Error Code: 00000000. Please help me to solve the problem.
May 22, 2011 | HP Office Equipment & Supplies
My Laser jet 1020 was Ok with Window Vista. Updated to Window 7 . Shows printer installed and available but does not print
You need to reinstall the drivers of the printer. You can download the driver from the link given below
HP LaserJet Host Based Plug and Play Package (Description: s.gif The Plug and Play Bundle provides basic printing functions.)You have to uninstall the printer already installed in your system, then you simply run this setup file and it will install drivers automatically and you should be able to get prints
if you require more assistance feel free to reply to this post
Regards, BA
Jan 15, 2011 | HP LaserJet 1020 Printer
My hp desk jet 722c printer will not print the hp desk jet 720c series toolbox icon states that data required by the printer driver cannot be found or has been corrupted can this be fixed or should i...
You need to reinstall or fresh-install the driver or the printer. Please let me know the installed Operating System on your computer (windows xp or windows vista or windows 7 etc.. etc..). I'll help you fix the issue.
Thanks and awaiting.
Oct 31, 2010 | HP Office Equipment & Supplies
When I click on file and then click on print the screen that comes up showing the name of my printer (hp6940 desk jet ) small wording comes up saying error=offline and my printer will not print the message...
-Try to turn off and turn on your printer
-check your connection
win xp
-go to start/setting/control panel/printers and faxes
-right click "hp deskjet 6940" and click on "use printer online"
win 7
-go to windows logo/control panel/devices and printer/right click on the printer driver, click on "see whats printering" click printer and uncheck use printer offline
Sep 04, 2010 | HP Deskjet 6940 InkJet Printer
SYSTEM ERROR CODE 04C300 C8CC0000 THEN STOPPED PRINTING MIDWAY THROUGH JOB iT SAYS TO HIT ENTER TO CONTINUE BUT GOES INTO A LOOP OF ERROR CODE /HIT ENTER, ETC
This is an IO error. Remove the back cover and disconnect the cables to the HDD and remove the JetDierct card. Print the internal test page. If it prints OK, install the Jet Direct card. Print again. Prints OK? Replace the HDD (or run without it). Does not print OK?
Replace the JetDirect card. Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Dec 16, 2009 | HP DesignJet 1050c plus InkJet Printer
My hp 3820 does not print on windows Vista
1) uninstall ur printer driver 2) restart ur computer 3) go to setup or install file of ur printer 4) right click on it and then click on properties 5) click on compatibility and change it to windows 2000 6) click apply then OK 7) click on setup or install file and keep on till ur driver will be installed
Jun 17, 2009 | OKI B4350 Laser Printer
It prints a sample but it won't print for me when I try to print something
Go to printer properties setup your printer......
then test print.... or a 2page file print current page.......ok
Feb 10, 2008 | HP DeskJet 6988 Printer
HP PSC 2510 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
