Question about Dryers
Bosch logixx 8 dryer keeps turning off.
Hi. I have a Bosch logixx wts84509gb/17 drier. It keeps turning off mid cycle (the screen goes blank and stops running). Takes about 5-10 mins and will be able to turn on again and runs again for a short period. I have run the test program P15 and showing an F14 code. Do you know what this might be?
  • 1003 Answers
SOURCE: LOCK ON & SHORT RUN PLD3460RDC1
REPLACE POWER CONTROL BOARD
Posted on Jan 18, 2008
IFIXALL
  • 868 Answers
SOURCE: machine runs for 4 hrs and 2H shows
Problem machine ,replace the control electric
Posted on May 21, 2008
ziraffa
  • 827 Answers
SOURCE: the treadmill keeps stopping Freespirit Model 12230520.0
Hey there,
If your treadmill has an optical speed sensor and hasn't been cleaned for a while, dust, dirt or lint may be obstructing the infared eye of the speed sensor. Try cleaning the treadmill.
Or maybe you need to replace the upper display, although, you may have a loose wiring harness that would cause the same problems. Open the motor case and verify the wiring harness is plugged into the lower board snugly. Also, remove the upper console and verify the harness is plugged into the back of the console snugly as well.
Definitely, inspect the components and try and isolate the source of the problem yourself first, before contacting a dealer for parts, as they can cost a fortune..
Good Luck!
Chris (ziraffa)
Posted on Dec 26, 2008
  • 6 Answers
SOURCE: dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Posted on Jul 30, 2009
Macmarkus
  • 2605 Answers
SOURCE: My Bosch dishwasher SHU43C02UC/38 runs the quick
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is the purpose of the "1" indicated in the display, a heating problem.
I`d first suggest calling in an authorized bosch servicer, however If you feel capable there`s a way to visually inspect the control. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution and leave a testimony.
Good luck.
macmarkus :)
Posted on Mar 12, 2010
Testimonial: "Thanks so much for the help - it was right on. "
Pls how can i unblock a pump on bosch logixx
Turn it anticlockwise
if it won't turn it has something inside jamming it
you will need to remove the pump and filter assembly and take it apart to clear it
Jan 08, 2015 | Bosch Logixx WFT 2806 Front Load...
Mid cycle it turns off and beeps and the anti crease/end button flashes
Possibly a blockage pump or drain outlet, check the filter behind the flap (bottom right on the kick panel).
May 31, 2013 | Bosch Logixx WFT 2806 Front Load...
Bosch logix8 comming up with the code nro
Bosch Logixx 8 error code nr0 means - The childproof lock has been activated.
Just deactivate the childproof lock.
Apr 10, 2012 | Bosch Logixx WFT 2806 Front Load...
Hi I have a Bosch Logixx 8 washing machine that
go to the manufactures website and download the user manual giving the model nr eric
Jan 19, 2018 | Bosch Logixx WAS2446 Front Load Washer
Bosch Logixx 8 Fabric conditioner not releasing into wash cycle
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Bosch Washing Machines
Have a Bosch logixx condenser dryer. key sign on screen
You have activated the child lock, basically you have held the start button for over 3 secs. turn the dryer to the cycle you want and keep your finger on ther start button to deactivate. If this doesn't work you may have a module problem. Double check your manual for child lock info. if no module go to link and enter you Enr number.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Jul 02, 2010 | Bosch Dryers
Time work problem
If it is relatively new, then my advice to you, is to contact the service agents, and get it looked at under guarantee.
Please rate my solution.
Thanks.
Sep 17, 2009 | Bosch Logixx WFT 2806 Front Load...
How do you remove Pump Cover on Logixx 8 washing machine?
I have a solution.You just keep turning the white knob anticlockwise. Use a pair of pliars to aid the turning keep going clockwise and anticlockwise if it gets stuck. It will rotate. Just opened my one and found a lollipop stick and a collar stiffner. Good Luck.
Feb 16, 2009 | Bosch Logixx WFT 2806 Front Load...
Whirlpool gas dryer stops in mid cycle and then starts up again
make sure of mode# make inside door and I will help you. also how old is your drier?
Feb 01, 2009 | Whirlpool LER4634J Electric Dryer
Bosch Logixx vented dryer not working correctly
I had the same problem.
I took of the cover on the back and found the heating element had blown. I just replaced it for a fraction of the cost of a new drier, just unscrewed it and conected the two wires easily.
Jan 25, 2009 | Bosch Logixx WFT 2806 Front Load...
Dryers Logo
Top Dryers Experts
