Red light flashin. Boiler not comin on. - Heating & Cooling
  • don-ohio Dec 31, 2016
    Hi George , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
2 Suggested Answers
  • 3 Answers
SOURCE: remote not workin
what's happened here is the cm61 ng and the reciver box have lost there connection you will have to "rebind" them then it will be fine -
THE BINDING OPERATION DESCRIBED BELOW IS REQUIRED IF:
· Any of the system components (room unit or relay box) are replaced
· HC60NG has incorrect or no binding data stored (e.g. when pre-bound system pack components have been mismatched)
· Interference with the RF signal has caused a communication failure
During the binding procedure keep approximately 1m distance between the room unit and the HC60NG
1 Turn off mains supply to HC60NG for 10 seconds. Re-connect supply.
2 Press and hold the HC60NG push button for 15 seconds to reset previously stored data. The red LED will start to flash at 0.1 s on/0.9 s off. Release the push button.
3 Press and hold the HC60NG push button for 5 seconds to enter the binding mode. Red LED flashing at 0.5 s on/0.5 off confirms the binding mode has been entered.
4 Move the CM67NG slider to the OFF position (CM61 push the OFF button) and press the TEMP , TEMP and PROG 1 buttons together. The CM61/67NG will display InSt.
5 Press the i button to send the binding signal. The red LED is switched off on the receiver box to confirm the successful binding operation. If the red light still flashes push the repeat steps 1-3 and press the the i button until binding is successful.
hope this is helpful
Posted on Feb 16, 2009
Steamer
Try running a phial of Kalstop through the boiler to descale the boiler unit. Calicification in the boiler and on the controlling solenoid can cause the unit not to produce steam. My boiler unit was so corroded that I had to get the boiler container completly replaced.
Feb 02, 2014 | Polti AS700 Canister Steam Vacuum
My ford 500 securtiy system is flashin and nothing is comin up on the dash board
If this is the security unit which came from Ford, try first the extra key. Otherwise you may need to reprogram it or have it bypassed by using a kit which is sold in the market.
Aug 04, 2011 | Ford Five Hundred Cars & Trucks
My blackberry pearl screen is not comin on the keypad light is not comin on but a redlight is blinking on top[
A blinking red light usually indicates a battery problem. If possible is there any way you can test the battery?
For more tips and tricks visit my blog at http://thegeektweet.wordpress.com
Jun 16, 2011 | RIM BlackBerry Pearl 8100
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
Drayton Digistat SCR thermostat not working.
Go online to www.cheapboilers.com who deal with this type of boiler. It would be very difficult to troubleshoot this boiler with the information supplied. I hope this will be of some help to you.
Sincerely, Shastalaker7
They should also be able to get you a manual for your thermostat.
Oct 27, 2009 | Heating & Cooling
I have a honda accord euro 2005 and the d light is flashin
does it affect the vehicles funtionality? if not i'd say a loose light socket or a shorted wire is likley the cause
Jun 22, 2009 | 2004 Honda Accord
Remote not workin
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
