How do you unstop the drain line on the wash machine
4 Suggested Answers
  • 7 Answers
SOURCE: ac drain is running under the floor pan how do you
look for a small tube under the motor on the firewall and unplug it
Posted on Sep 29, 2009
SOURCE: dishwasher want drain .what steps should i take to
There's a few things you can look into that won't cost you any money.
First, manually remove as much water as possible and then check the sump area for paper or any other large object clogging the drain. A cup or so of water in the sump area of your dishwasher is normal and it is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
Make sure the door is properly latched as the pump will not drain if the door is not latched properly.
Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it’s possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn’t turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
if you need to buy any parts, I have had alot of help from http://www.apwagner.com
Small objects can sometimes get stuck in the pump. When this occurs, you’ll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Posted on Sep 03, 2010
  • 297 Answers
SOURCE: How do I unstop drain line
Hi John, you may have a clog on the inside of the unit. look for a screen or a port of some sort in the bottom of your unit it may have debri stuck over or inside. Hope this helps.-Bill
Posted on Jan 19, 2015
How do i unstop the faceboard in the bathroom
You might be able to use a small hooked wire to remove the clog.
These can be purchased commercially, or fashioned at home from hobby, internet, or electrical wire.
http://handyhook.net/
May 07, 2016 | Washing Machines
Water leak in my range rover on driver side floor had drain unstop from sunroof what else could it be
You unclogged the sunroof drain line - that is good. Are you sure that the line didn't pull up thru the floorboard. Many vehicles run the drain line down the drives side window pillar and out thru the floorboard. If the hose shrinks with age (as some do), they can pull up into the cabin and leak on the floor.
Nov 09, 2015 | Rover Cars & Trucks
A/c drain line stopped up. leaks into floor of front passenger seat
Sometimes you can unstop the drain hose with a coat hanger.
Aug 12, 2015 | 1999 Jeep Grand Cherokee
Drain pipe
It sounds like the drain in your wall is clogged. Try using Drano or similar product to unstop. If that doesn't work you may need to call a plumber.
Jan 01, 2013 | Plumbing
I am having problems with A/C condensation leaking inside with flooding the front and back floor of Car
check your drain hose for blockage, if it's clogged up the condensation will leak into the floor
Jul 19, 2010 | 2004 Mazda RX-8
Where is the a/c condensation line drain located on a 2004 buick rainier. the passenger side carpet in soaked and I think the a/c drain line is stopped up
Look under the hood where the ac lines go into the firewall,and look directly below it,it may have a elbow boot like thing on it,just pull it off and use compressed air to blow the drain out,it will come out like a water fall when it is unstopped,if this was helpful,please rate,thank you.
Jul 17, 2010 | 2004 Buick Rainier
Drain hole stopped up in freezer and we cant get it unstopped and it is leaking down in to frige. do you know how we can get it unstopped?
pull back panel in freezer, take hair dryer and melt ice around drain hole until it starts to drain may take sometime usually 20 30 mins pour hot water in drain pan to verify that it is draining
Jan 03, 2010 | Roper Refrigerators
Ac drain is running under the floor pan how do you unstop drain line
Sep 28, 2009 | 2001 Mitsubishi Eclipse
Remove the freezer back wall and lower panel. Remove the visible ice. Use a hair dryer to defrost the drain hole in the rear trough.
Mar 13, 2009 | GE Refrigerators
Washing Machines Logo
Top Washing Machines Experts
