Question about Radio Communications
The Bluetooth connection has gone for the second time and won't connect to any devices, the 1st time it just started working on it own. The unit is only 12 months old. Is there anything I can do
rockfixya
  • 679 Answers
SOURCE: Connection problem for Philips VOX130 with other bluetooth devices
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select VOX130 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
dougjr76
SOURCE: jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Posted on Feb 08, 2009
SOURCE: Connecting two devices on BT3030 headphones
A method to do pairing in "the second channel."
  1. Trun off BT3030 first.
  2. Continue pushing the power button till "Jabra" mark turns on pink next.
Attention: Continue pushing the power button after "Jabra" mark became the blue.
Posted on May 30, 2009
SOURCE: bluetooth "device out of range or powered off"
I had lots of trouble too. I thought it was my phone. Well here's what you do. First off remove the device completely from your phone. Turn off the phone and take the battery off so it can re-boot. When the phone is powered back up put your bluetooth in pairing mode and get it back on your phone. It should connect without any problems. Now....here is the trick. When you want to disconnect the device(bluetooth) from your phone don't turn it off on your phone. Shut the actual power off on your bluetooth. The phone will recognize this and disconnect the device. The only thing left on your phone will be the bluetooth icon. Being the icon still on your phone it is still in discovery mode and can overtime use up your battery life searching for a device. This is when you can go to your phone and turn off the bluetooth. On your NV 2 go to your bluetooth menu and just use your left softkeyto turn it off. Now there is no connection whatsoever. And to turn it back on do the opposite. Go to your bluetooth menu and turn on your bluetooth. You will see the bluetooth icon. Now you power up the bluetooth and it will connect as soon as it get the signal. This took me 2 weeks of trial and error and other stuff but I am happy now and I hope this solves any bluetooth problems...
Posted on Jun 06, 2009
micromatikal
  • 2777 Answers
SOURCE: i have nokia e71 mobile
The passcode is just "0000" without the quotes of course.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Posted on Oct 21, 2010
Having a problem pairing my iPhone 6 to my Tx-sr333 receiver. Iphone just grinds and can't find Bluetooth.
Hi Don,
Pairing is necessary when using the Bluetooth-enabled
device for the first time. Before starting the procedure, learn
how to enable the Bluetooth setting function and to connect
with other devices on the Bluetooth-enabled device.
1. Press BLUETOOTH on the remote controller.
The unit enters the pairing mode and the BLUETOOTH
indicator starts flashing.
2. While the BLUETOOTH indicator is flashing,
complete connection on the Bluetooth-enabled
device in the nearby area within about 2 minutes.
If the name of this unit is displayed on the Bluetoothenabled
device's display, select this unit. Paring will end
after a short time.
???? If a password is requested, enter "0000".
???? When connecting the unit to any other Bluetoothenabled
device, start pairing by pressing and holding
BLUETOOTH until the BLUETOOTH indicator starts
flashing. This unit can store the data of up to ten
paired devices, Thanks, JT
Mar 09, 2015 | Onkyo Audio Players & Recorders
Jbl flip does not connect by bluetooth
Press and hold power button while trying to connect to new device to reset conmection
Dec 27, 2012 | Harman Kardon JBL Flip black
Bluetooth connection not working. Tried with a couple of phones to find the player with no success.
Make sure that the mobile phone which you're trying to use is paired with the Car Audio System.
Check if the Blue-tooth icon at the front panel display is lit.
If the pairing is completed, try connecting the device to the head unit. Press and hold the BT button for 3 seconds to connect the mobile phone unit to the Car Audio system.
If the unit is not getting connected, then try to RESET the unit by pressing the Reset button located inside the front panel using a sharp pointed object. Once the unit is reset, try pairing the unit again and then connecting the devices.
You may also check the compatible Bluetooth devices with the Car Audio System.
Feb 15, 2011 | Sony MEXBT3800U Xplod Bluetooth for Car or...
My Microsoft Bluetooth Mouse will not stay connected to my system
1. Go to Start->Run and type in "services.msc" and click OK
2. Find "Bluetooth Support Service" in the list of services and double click to open the properties window
3. Click on the "Log On" tab and select "Local System Account" for "Log on as:"
4. Click Apply and OK
5. Right click on "Bluetooth Support Service" and select stop then right click on "Bluetooth Support Service" again and select start
6. You may need to reconnect your bluetooth devices; everything should be working now.
Nov 18, 2009 | Microsoft IntelliMouse Explorer Bluetooth...
Have blackberry flip phone, blue tooth worked fine,now shows bluetooth:disabled, can't get it to work HELP gene
Hi to enable Bluetooth follow the steps given below: 1. Click on OPTIONSfrom the main Menu 2. Click on Bluetooth then 3. Click on the Menu key (which is next to track ball) 4. click on Enable Bluetooth If you find any problem please contact the Service Provider of your SIM Thank you for using Fixya
Nov 13, 2009 | Cell Phones
Got a New Nokia BH-106 bluetooth Headset, i'm
i purchase new Nokia bluetooth headset BH-106 and i want to connect my laptop ( Dell INsprion N5010) plzz give some advise who to connect it.
Sep 21, 2009 | Nokia BHF-2 Headset
How do you pair your Insignia Headphones/ Headset with a PS3? It is called an insignia NS-BTHDP/NS-BTHDST. In the instructions it only talks about pairing it with a computer. Can someone help me?
Go to Accessory Settings on your PS3.Then go to mange bluetooth devices and hit register new device. while doing this take your headset and put it in discovery mode. You do this by holding the power button and the it alternates between blue and red lights.It should work after that.
To test it go to audio device settings and see if it shows up.
Mar 26, 2009 | Insignia Bluetooth Wireless Headphones...
Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
Feb 27, 2009 | Motorola Mobility S9 Headphones
Bluetooth not picking up mp3
@psychurmine you may need to go into the settings of the actual music player application on your phone and tell it to output to headphones.
@ejr420hotora it could be several problems. Did you have it working at one point or is this your first time installing it? Is this your first bluetooth device or do you have others?
Feb 12, 2009 | Insignia Bluetooth Wireless Headphones...
Bluetooth
Sir
1st tap on start .
2nd tap on settings.
3rd tap on connections.
4th tap/select bluetooth Icon.
5th tap on mode there mar both Turn on bluetooth & Make my device visible to others.
6th add new device.
7th u will see the name there of ur bluetooth device / Headset.
8th select the one wch is ur.
9th enter a pass key 0000
10th make ths device authorised and connect to headset
TRY it and mail me soon
at ( lovedeepsingh_35@yahoo.co.in)
Jun 29, 2008 | AT&T 8925 Tilt Smartphone
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
