Question about Nikon Coolpix S9300 GPS Digital Camera Silver with 8GB Card Battery Case
Coolpix s9300 won't charge only the flash light flashing won't turn on new battery installed but still no joy ??
  • Nikon Master
  • 5,412 Answers
Are you using the Nikon charger or a substitute ?
Posted on Dec 18, 2016
Camera is dead , battery is fine , nothing turns on
Nikon Coolpix S8200 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_s8200_Troubleshooting
iFixitThe Nikon Coolpix S8200 model was released in August of 2011 with a ... Flash won't work, but light bulb is fine; Flash is enabled but still won't go off. Camera won't turn on¶. You have tried turning on your camera and nothing is happening. ... Once a green light turns on, it is telling you that your battery is fully charged.
Coolpix S4000 won't turn on? - ePHOTOzine
https://www.ephotozine.com/.../coolpix-s4000-won-t-turn-on--97474
Jun 4, 2012 - Still won't power up mine so I am giving Nikon a call in the morning to see if they can figure out .... started up with both batteries all fine & dandy
Problem with Nikon Coolpix P510: Nikon Coolpix Talk F
Jan 08, 2016 | Nikon Coolpix S6700 20.1 Megapixel Compact...
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
Why my s9300 will not come on
While charging, did the charger act normal? on the end the light was burning continue?
If so we have to assume the battery os charged. Then check the contacts on the battery and in the camera. They should be clean and shiny. Not coming on means not even the lens barrel moves an inch and you can't view pictures on the card and you can't change the menu.
It should really be the battery. Also make sure you did close the battery cover, because there is a little switch, checking if the door is closed. The camera won't start if it is not closed correct.
Last I hope you did not manage to revers the battery.
Jul 16, 2014 | Nikon Cameras
Camera does not recognize batteries.
Your batteries are worn out and need replacing for new fresh ones. They are charging, but not holding the charge. If they are new, they are fakes or worn out.
You can buy batteries which have a higher capacity, more MaH (milli-amp hour) than your current ones.
Having a quick Google, it is a known problem.
try this ... i had the same problem with the same camera and this fixed it.
remove the battery, and remove the memory card ... then re-install the battery & turn on the camera.
this process seems to reset the camera, if the battery ran too low.
now you can re-install the memory card & battery and resume normal operation.
be sure to check for the small flashing green light on the back of the camera (next to the "flash" indicator symbol). it should be blinking when the camera is charging.
i hope this helps you.
nikon coolpix battery exhausted message Google Search
Feb 10, 2018 | Nikon Coolpix 4600 Digital Camera
My Nikon Coolpix S3100 won't turn on
I had the same problem, and many other people have had this issue. The camera sat for too long, and the battery fully discharged. It needs to be reset. In order to do that, remove the battery and memory card. Replace only the battery, and plug it in. You should see a green light flashing to the right of the LCD screen. That means it is now charging. Replace your memory card, and let it charge before trying to use it.
Apr 30, 2012 | Nikon Coolpix S210 Digital Camera
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
My coolpix s3000 camera won't turn on after just taking it brand new after the box (I did put the battery in correctly and it is currently charging with the green light flashing on and off and I have also...
1) Please charge the camera and make sure the GREEN LED flashes.
2) When the green LED STOPS flashing disconnect the camera from the charger and wait a few seconds.
3) Now that the Camera is off attempt to turn it on. It is in a half way on while charging and you cannot 'turn it on'.
4) In review: Charge it, Disconnect it and turn it on.
Dec 22, 2017 | Nikon Coolpix S3000 Digital Camera
Turning off after taking a picture with a flash
Sorry but that is just because the flash is recharging.. It turns the screen off so it can charge the flash faster.. No worries it works fine :)
Jan 24, 2008 | Nikon Coolpix 4600 Digital Camera
Nikon Coolpix S9300 GPS Digital Camera Silver with 8GB Card Battery Case Logo
95 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
