Question about Refrigerators
My U-line1215S-00A has water flowing in but no ice. Everything is connected and had ice for about 1 year. Now no ice is being produced.
fridgetech
  • 473 Answers
SOURCE: Whirlpool Side-by-Side Refrigerator No Water to Icemaker or Door
Check to see that you do have water to the water valve on the fridge. You can disconnect right where the water line goes into the valve on the fridge. Next, if you can, check power at the valve while activating the water dispenser. If you have power at the valve when activating then the water valve is bad. Let me know what you find.
Posted on Oct 10, 2007
  • 1073 Answers
SOURCE: Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Posted on Apr 17, 2008
SOURCE: Water doesnt stop after ice tray is filled
My amana sxd25s2w side by side, water dispener just stopped working all at once. I hear a click when pushing the bar, and the light goes on but no water. Also the ice maker is over flowing when it fills the tray. Are these 2 things related and I would like to replace the filter for the water , where can I find that. Please help!
Posted on May 04, 2008
tech master
  • 120 Answers
SOURCE: too much wate flow into icemaker
it over filling or it leaking from the mold i never seen thi model over filled mold when i see wtr in bin is usually the mold that is leaking you can check with a mirror or remove to inspect is texture is peeling off repl entire ice maker if is ok then repl wtr valve is not closing when it has filled the mold you only need 4oz of wtr
Posted on Nov 03, 2008
  • 3 Answers
SOURCE: Low flow indicator light comes on chronically.
If you have excessive calcium in your pool the calcium will solidify on your titanium plates. Look for little bits of white scale (looks like paint chips) in the pool usually by the outflow. To fix, unplug the chlorinator, remove the inflow and outflow hoses from the chlorinator, also remove the flow meter (piece of pipe that has the wire attached to it. Look in at the titanium plates. If it has white calcium coating it, then flush with the hose till it all comes off, if it doesn't come off remove that piece of PVC and soak in vinegar (haven't had to do that but thats what the manual says). Manuall says to drain 25% of your pool and refill with fresh water but I elected to just keep cleaning it out when the alarm went off untill all the calcium in the water turned to solid (had to clean 3 or 4 times). Be sure and vacuum up the calcium in the pool.
Posted on Jul 22, 2009
Ice maker stopped making ice
hi,
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Oct 03, 2008 | Whirlpool GS6NBEXR Side by Side...
My LG refrigerator will not produce ice cubes, only crushed ice.
Ice maker makes crushed ice.
1)For every 6 moths or 1 year you have to replace the filter.The decreased flow is caused due to filter problem.You said you cleaned the filter and the problem still persist.
2)Check the valve see the below picture how ice dispense parts interconnected.Thepat no 15 the valve which will be blocked by ice or dust you have to remove it.Can you see the valve 22 will connected down of water tub.SO check the valve is not frozen.
Simple if the valve decreased flow or crushed cubes means there is some block.May be due to dust or frozen ice.
Note:Just switch of the switch for 8 hours or more and let the frozen ice melts on the valve.Please see to it all the frost melts fully.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 18, 2010 | LG Refrigerators
Ice maker will not produce ice, no water flowing to dipenser.
Sounds like the water filter is plugged up...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Aug 29, 2009 | Kenmore Refrigerators
Will not make ice, water line is connected and turned on, and water dispenser works fine.
HI,
Jul 03, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker in Kitchen Aid stopped making ice
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Replaced icemaker with new one but still not working
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
Jan 06, 2009 | Refrigerators
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
