Question about Exercise & Fitness
Sensor wiring for horizon oxford 2 cs air rower Need the wiring from the plug where machine folds as plug is damaged & the 3 coloured wires in socket do not match the colours in plug
My 2004 Honda CRV showing code P0133 and P0171
  • P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
  • P0171 System Too Lean (Bank 1)
Hi Michael, After fixing errors you need to reset your computer by disconnecting the battery for a minute or two, Also you'll need your radio code to reset your radio, I hope this helped...........CHEERS..
May 07, 2016 | Honda Cars & Trucks
Vintage singer 3 pole plug wireing
WIRE WITH COLOUR GREEN OR WITH SOMETIMES GREEN WITH YELLOW STRIPE IS THE EARTH WHICH HAS TO THE TOP ONE USUALLY MARKED WITH AN ANTENNA SIGN UPSIDE DOWN. BROWN COLOUR WIRE IS USUALLY LIVE WHICH IS MARKED IN PLUG AS (L) AND BLUE COLOUR WIRE IS NEUTRAL USUALLY MARKED IN PLUG AS (N).
IN CASE THE COLOUR DIFFERS OR ELSE THE PLEASE INFORM SO THAT WE CAN REGUIDE YOU.
Aug 31, 2012 | Sewing Machines
Spark plugs
Check this SPARK PLUG REPLACEMENT - REMOVAL PROCEDURE
1. Remove the ignition coils (lines at end this document), then return here once you have gotten the Coil
Packs off and precede with step 2 from here.
2. Clean the spark plug recesses with low pressure air. CAUTION: Wear safety glasses
when using compressed air, as flying dirt particles may cause eye injury. NOTE:
Clean the spark plug recess area before removing the spark plug. Failure to do so could
result in engine damage because of dirt or foreign material entering the cylinder head, or
by the contamination of the cylinder head threads. The contaminated threads may prevent
the proper seating of the new plug. Use a thread chaser to clean the threads of any
contamination.
3. Remove the spark plugs from the cylinder head. NOTE: Allow the engine to cool before
removing the spark plugs. Attempting to remove the spark plugs from a hot engine may
cause the plug threads to seize, causing damage to cylinder head threads.
4. Inspect the spark plugs.
INSTALLATION PROCEDURE
1. Measure the spark plug gap on the spark plugs to be installed. Compare the measurement
to the gap specifications. NOTE:
• Use only the spark plugs specified for use in the vehicle. Do not install spark
plugs that are either hotter or colder than those specified for the vehicle. Installing
spark plugs of another type can severely damage the engine.
• Check the gap of all new and reconditioned spark plugs before installation. The
pre-set gaps may have changed during handling. Use a round feeler gage to ensure
an accurate check. Installing the spark plugs with the wrong gap can cause poor
engine performance and may even damage the engine.
2. Install the spark plugs to the cylinder head. NOTE:
• Be sure that the spark plug threads smoothly into the cylinder head and the spark
plug is fully seated. Use a thread chaser, if necessary, to clean threads in the
cylinder head. Cross-threading or failing to fully seat the spark plug can cause
overheating of the plug, exhaust blow-by, or thread damage.
• Refer to Component Fastener Tightening Notice in Service Precautions.
Tighten the spark plugs to 18 N.m (13 lb ft).
3. Install the ignition coils.
IGNITION COIL(S) REPLACEMENT
REMOVAL PROCEDURE
1. Remove the air cleaner resonator and outlet duct.
2. Disconnect the engine wiring harness electrical connector (1) from the oil pressure sensor (2).
3. Disconnect the engine wiring harness retainers (1) from the power steering pump (2).
4. Disconnect the engine wiring harness electrical connectors (1, 4) from the following:
• The exhaust camshaft position (CMP) sensor (5)
• The camshaft position (CMP) actuator solenoid valve (6)
5. Disconnect the engine wiring harness retainer (2) from the camshaft cover (3).
6. Disconnect the engine wiring harness electrical connectors from the following:
• The engine coolant temperature (ECT) sensor (1)
• The fuel injector harness (2)
• The ignition coils (4)
• The heated oxygen sensor (HO2S) (5)
7. Disconnect the engine wiring harness electrical connector from the intake camshaft position (CMP) sensor.
8. Carefully disengage the engine wiring harness conduit from the camshaft cover, and position aside.
9. Remove the ignition coil bolts.
10. Remove the ignition coils from the camshaft cover.
1. Install the ignition coils into the camshaft cover. IMPORTANT: Ensure the ignition coil seals are properly seated to the camshaft cover.
2. Install the ignition coil bolts. NOTE: Refer to Fastener Notice in Service Precautions. Tighten the ignition coil bolts to 10 N.m (89 lb in).
3. Attach the engine wiring harness conduit to the camshaft cover.
4. Connect the engine wiring harness electrical connector to the intake CMP sensor.
5. Connect the engine wiring harness electrical connectors to the following:
• The ECT sensor (1)
• The HO2S (5)
6. Connect the engine wiring harness electrical connectors (1, 4) to the following:
• The exhaust CMP sensor (5)
• The CMP actuator solenoid valve (6)
7. Connect the engine wiring harness retainer (2) to the camshaft cover (3).
8. Connect the engine wiring harness retainers (1) to the power steering pump (2).
9. Connect the engine wiring harness electrical connector (1) to the oil pressure sensor (2).
10. Install the air cleaner resonator and outlet duct.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jan 23, 2012 | Cars & Trucks
How to change spark plugs in a 2005 chev colorado
contamination.
REMOVAL PROCEDURE
• The HO2S (5)
Hw60-1460d error code3
just fixed mine take large white panel off at rear of machine look straight in below the drum two grey coloured wires going to temp sensor touched one of them and found wire was broken stripped wire back and crimped on new connector push on spade type.checked other one was ok. turned on machine hey presto error3 was gone machine ok hope this helps.
Nov 25, 2011 | Washing Machines
I need to know which wires from my air box plug are the IAT (Intake Temperature Sensor) and which are the MAF (Mass Air Flow) wires.
sorry i do not know the colours off the top of my head, but the IAT it the small 2 wire sensor about halfway up the air duct, and the MAF is the large multi wire connector close to the air filter box. good luck!
Apr 27, 2010 | 2005 Pontiac Grand Prix
Clips on polar transmitting wire has snapped on my horizon oxford 2 rower, where can i get the clips?
You can get the clips from the manufacturer but an easier way to secure the wires would be with velcro straps,available at Home Depot & Lowes. They come in packs of 5 and 10 and they don't cost nearly as much as the clips will. They also won't break if you bump them.
Nov 25, 2009 | Exercise & Fitness
I repair my Equinox 2007 under seat after that the passenger airbag is shown OFF ?? I havnt seen any problem before under seat repairing .
HIYA!
All Equinoxes has yellow coloured wire harness to identify this as a air-bag system.
This yellow coloured wire 'system network' has connections in some areas...one is located at the front passenger's floor area close to the door (right-side corner area, just remove screw or clip and plastic trim part to gain access to see yellow wire there-it has socket plug connected with red clip-string to secure it) and another yellow wire is found between the front seats-you need to remove armrest, center console area and possible remove the front passenger seat to see yellow wire connect to black device underneath carpet in the middle.
Check to ensure the yellow wire sockets are plugged in properly, and not accidently cut or pulled off during your underseat repair.
In case your Equinox has roof side air-bag option, the yellow wire/sensor are located below the front seatbelt device inside the lower pillar frame area. (it's between the doors)
Hope this help you solve your repair task.
Jan 11, 2009 | 2005 Chevrolet Equinox
Exercise & Fitness Logo
53 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
