You The NVR has lost it's IP Address, I can't find it on the internet explorer and I can't ping it on command line. Is there any way to restore the NVR NAPCO factory settings.
SOURCE: Setting IP Address
I finally got the unit to work. I reset the unit a couple times to factory default. arp -s command for the ip address, set up the port in my windowsxp for the set ip. Shut everything down and started it back and it worked. Thanks for the help
Posted on Aug 20, 2007
  • 233 Answers
SOURCE: no internet after factory restore
Call your Internet provider
Posted on Nov 01, 2007
  • 102 Answers
SOURCE: Nortel VPN Router 100 Nat Configuration Command
If its a router using configuration list then usually they work negatives by adding NO before the command line.
Try 'NO NAT add ip X.x.x.x'
OR if the access list has numbers per each line command simply put:
NO NAT then the line number.
Make sure that you are in the correct interface and access list to do.
If nothing works then consult:
Hope that helped
Posted on Dec 14, 2007
  • 427 Answers
SOURCE: route-map policy block the ICMP
honestly, I dont think anyone here will know how to handle this problem. Try to show this problem to a trained professional.
Posted on Mar 23, 2008
SOURCE: ICMP blocked automatically
return, cut this configuration, but put route the her isp´s.
You can ping after this?
Can´t ping you has other problem.
Posted on Mar 28, 2008
How to ping server name
find command screen on windows computer. XP it is under accessories. On windows 8 you have to use the search facility to find CMD.
On black command screen enter command
PING "server name" where "server name" is the server you want to find such as
Jul 02, 2014 | Intellinet Active Networking 802.11b/g...
I have a dell optiplex gx520,it is hooked up to wireless connection and it's showing that the signal is good,but IE won't let us view webpage......
can you check if have a valild IP address?
1. Start > RUN > type in "cmd"
2. On the command prompt windows (black DOS window),
> type "ipconfig" > hit Enter
> you should have a valid IP address (something like 192.168.x.x)
• if yes, then try to ping a website
• if no, (you should see somthing like 169.254.x.x), check your wireless settings again.
**good signal doesnt mean that you are connected, it could be a conflict with wireless encryptions too..**
3. to perform PING
> on the CMD screen (back DOS based window), type "ping (space)"
> you should see ping statistics, something like "packets sent=4 received=4 lost=0"
• if 0% lost > your connected to the internet
• if 100% lost > you have no connection
> again check your wireless again
4. If you can Ping and you can't still view webpages using IE here's what I suggest
• Optimize your browser
-delete temporary internet files and cookies
4a.1 Open Internet Explorer
4a.2 Click "Tools" (the icon that looks ike a cogwheel / gear; usually at the upper right corner of internet explorer)
4a.3 Click "Internet Options"
4a.3 Click "Delete" under the General Tab Screen
4a.4 Restart Internet Explorer
• Reset Internet Explorer to factory settings
4b.1 Open Internet Explorer
4b.2 Click "Tools" (the icon that looks ike a cogwheel / gear; usually at the upper right corner of internet explorer)
4b.3 Click "Internet Options"
4b.4 Click on the "Advanced" tab
4b.5 Click on "RESET"
4b.6 Restart Internet Explorer
Hopes this Helps
Aug 09, 2011 | Computers & Internet
My net book is showing a Local intranet and not the internet how can I fix that
Hi there
When we say your computer is showing local intranet but not the internet then it must be an issue with some of the settings and could also be firewall settings. Lets try these steps to check whats going on.
First i'd say please go to command prompt (START -> RUN -> CMD)
(Normally the IP ADDRESS starts 192.168.xx.xx)
Then PING the Default gateway by entering the Default Gateway( Command for pinging the default gateway is PING "default gateway number")
Check whats the reply you are getting and it should say Packet Sent=4, Received =4 and Lost =0.
Then type ping and check whether you gets the same reply Packet Sent=4, Received =4 and Lost =0.
If you gets all these positive then there is no problem with your network. We have to check for the internet explorer settings. First you check with this settings and revert with details. So that i ould be able to assist you better.
Dec 30, 2010 | Sylvania G-Netbook
I have one Epson TMU220PD printer. I have to set its IP address. how can I do it. Also, i want to know its default IP. Thanks, Saket
switch on your printer while pressing feed button.printer will print some pages and u can read ip address of printer in printed page.Then add same ip range in ur computer.connect printer to pc by network cable.test ping command to printer ip address.if ping succes then open internet explorer, type printer ip address in address bar, press enter key..there u can set ip adress from tcp ip options.
Oct 23, 2010 | Epson TM-U220 Matrix Printer
Not laptop my home computer keeps saying internet explorer cannot display webpage its signal is excellent
Check if you have an IP address for the computer Check if you can ping any website using Command prompt If it pings with command prompt, then try with a different browser If it not getting IP or not pinging the website then it is an issue with the network settings
Jul 10, 2010 | Microsoft Internet Explorer 7
How do I ping my router (using XP). Lost my internet connection, but 2nd computer working fine with internet connectivity.
Find the IP address for your router, open a DOS window. the command is "ping" enter the ip address.
for example ... Ping
May I recommend Network Magic to you . Google it ... free to download with free evalu period. You can read the deal there. I use the paid pro version and I love it.
Oct 04, 2009 | Computers & Internet
I cannot access my internet or download. Previous
Check in command prompt if u can ping websites ,check IP address . Ping in command prompt. Do ipconfig /release and then ipconfig /renew.
If u can ping google in command prompt issue with Internet explorer try different browser.
Aug 17, 2009 | Computers & Internet
Lost connection
1. check ip address in command prompt
2. If unable to find valid ip address , reset ipaddress , in command prompt type ipconfig /release and then ipconfig /renew
3. Ping default gateway in command prompt
4. then ping in command
5. If u can ping in command prompt issue with Internet explorer or with Operating system.
6.Try using different browser.
Aug 17, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Cannot connect although plugged in
Check the ipaddress. Type ipconfig in command prompt. Then ping a website in command prompt if u get proper ip address e.g Try to ping in command prompt. If u are unable to connect. Tried to release renew Ip address.
Type ipconfig /release then ipconfig /renew in command prompt. If you are able to ping google and still unable to connect to website using internet explorer, then issue with browser or with OS.
Computers & Internet Logo
David Payne
David Payne
