Question about Furniture
Dansby wine cooler temperature light keeps blinking, what could be causing this?
  • 833 Answers
SOURCE: Haier BC112G Wine Cooler Beeping and overcooling
That thing that's beeping...it is the circuit board. It is telling you that it wants a new cousin to live in your house. Replace it.
Posted on Dec 21, 2007
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
  • 218 Answers
SOURCE: wine cooler
Try this website. http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=224777abd6c75c24622a757a6f5ff1ba&q=Magic+Chef+MCWC30MCG&e=1
Posted on Jul 27, 2008
  • 286 Answers
SOURCE: U-Line 15WC wine cooler not working
First make sure your condenser is clean and the fan is going. If everything is running and still doesnt cool enough then you need a repair person to check the sealed system.
Posted on May 18, 2009
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
Temperature lights blinking
Did you ever get any info on this problem? We are having the same issue. Thanks
Mar 16, 2013 | KitchenAid KUWA244PBS Wine Cooler
Why would I need a single zone wine cooler?
The single zone wine coolers is advised when you want to keep only one type of wine, red wine or white wine, since they don't have the same optimal storage temperature (and you only have one chamber.
Aug 14, 2012 | Furniture
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
I always thought that light was bad for wine. Why is it that almost every wine cooler is look at has bright lights built inside?
The lights in a wine cooler are LED lights. These are safe forms of lighting to use as they will not raise the temperature of your wine.
Jul 31, 2012 | Furniture
Other than temperature, is there any other reason not to store wines in a regular fridge? I don't mind my wines being slightly cooler and I can always leave them on the counter for 10 minutes bef
Aside from temperature, humidity is a major concern. The low humidity levels can cause the cork to dry/shrink allowing room for both air and other food odors to enter the bottle and tamper with the quality of the wine inside. Wine coolers offer an optimal humidity level of 50-80% needed to keep your wine in good condition.
Can I keep red and white wine in the same temperature?
Not recommended. Red and white wines are different worlds and in order to preserve the wine better you need to keep the wine in the recommended temperature: Red wines at 12.7-15.5 C and white wines at 9.5-13.3 C
May 29, 2012 | Furniture
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
The alarm in our Franklin Chef model FWC100 wine cooler keeps going off even though everything stays cool so we want to know how to turn off the alarm or cut the wire to the alarm. Thanks.
Love this machine. Works great. Have had it for 6 years. Now it has a problem. The lights and fan work, and the temperature settings work. It behaves like either the freon is low (I don't hear the compressor starting), or whatever causes the compressor to start is crippled... Fuse looks good, nothing visibly burned on the motherboard, haven't opened the bottom.
Jul 29, 2011 | Franklin FWC100 Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Furniture Logo
149 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
