Question about Bernina Sewing Machines
My Bernina 380 stitch length adjustment is not working
  • Bernina Master
  • 11,205 Answers
Be sure that you raise the presser foot when threading the machine. However, I suspect that is not the cause of your problem. Check your machine's feed dog action to see if they are actually moving. Since it is a computerized machine, it is probably best to take it for service.
Posted on Dec 18, 2016
The zigzag stitch will adjust width but not length
If it's a mechanical Bernina, it could be some of the lever mechanics have seized from old, dry oil. You can try liquid Tri-Flow Synthetic Oil--a couple drops where metal rubs on metal to see if it loosens things up. Applying hot air from a handheld hairdryer will help speed it up. The other possible alternative is that something is no longer attached to the knob/lever.
If it is a computerized Bernina, you should probably take it for service.
Aug 04, 2016 | Bernina Sewing Machines
How to adjust stitch length on my 930 record? I need to make length longer.
On the right side of your machine, there is a lever that moves up and down that has lines marking 1 through 4. Setting it on 4 will give you the longest stitch length available. If you push the lever all the way up above the numbers, it will reverse stitch.
Sewing Machines Bernina 930
Aug 25, 2015 | Sewing Machines
How do you set the length of the bobbin stich
The bobbin works with your top stitch ..when you set the length of the stitch then it goes the same as the top
Mar 06, 2015 | Bernina Sewing Machines
Stitch length irregular on my bernina sewing machine
This could be a number of things.
Try removing the needle plate and cleaning out any lint in the feed dogs.
A lot of machines have adjustable presser foot pressure, perhaps it needs to be adjusted.
Feb 28, 2015 | Bernina Sewing Machines
I have forgotten how to work my Decorative stitches on my Bernina 930
select the 1-20? stich pattern on top of the unit, then select the pattern you want, select widest stich and turn the length adjuster to the length that best suits that stich, (it could be from almost zero to full length depending on the pattern)
Feb 07, 2013 | Sewing Machines
Is there a button on this 807 machine bernina which you can press for it to stitch backwards like on the singer machine 507 as its saves time on tiring ends up at the beginning and end of sewing thank...
The stitch length control is moved upwards, beyond the 'zero' position to make it sew backwards. To demonstrate, with the machine off, adjust the stitch length to '2' using the knob on the stitch-length lever. Now push the lever upwards until it stops - it will go past the zero position and this is now in reverse mode.
May 15, 2011 | Bernina Activa 130
All my decorative stitches come out messed up. None of them are right.
Usually that means to stitch length balance needs adjusting. Adjustment usually must be made by an authorized service technician for your machine. Check your user manual to determine if you can adjust the stitch length balance.
Good luck.
Sep 26, 2009 | Bernina Sewing Machines
Bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Jul 27, 2009 | Bernina Virtuosa 160
Sewing Machines Logo
29 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
