Question about Refrigerators
My digital display no longer comes on when the door is open why ? Fridge works perfectly fine ..hisense
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Posted on Feb 02, 2008
  • 531 Answers
SOURCE: Fridge worked perfect for 3yrs, one day i took
you may have a big problem not sopose have the door open so long better you call service
Posted on Apr 02, 2009
aasc
  • 1606 Answers
SOURCE: a clicking sound was coming from behind my fridge
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Posted on Sep 25, 2009
  • 6 Answers
SOURCE: Sharp SJ-42-WH self-defrosting fridge. Freezer
I recently had exactly the same problme with this model refrigerator. I found the problem to be the defrost timer. It is located behind the panel on the back of the refrigerator where the mains cord is located, you will need to replace it with the exact same model. I am in Australia and managed to find the exact part on ebay cheaply from a local appliance parts supplier, any appliance parts supplier that deals in Sharp refrigerators should be able to help you.
You will have to defrost the refrigerator overnight again before doing this repair.
Of course there are a couple of other components that could cause this problem, you can acutally check to see if the defrost time is moving by taking note of it's current position and then checking it every thirty minutes or so. If it does not move then it could be faulty, make sure also that power is getting to the timer as well.
Posted on Oct 27, 2009
  • 128 Answers
SOURCE: Regarding GE french door model pfs221sbss, need
I would call your GE service company and give them the model number and serial number of your frig. They can look up which board fits your frig.
I hope this helps.
Posted on Feb 03, 2010
Testimonial: "Will do. Thanks- BW"
I have just had a Hisense Black Glass French Door fridge delivered. It will not fit through the door way. Can I remove the doors. There is no external water/ice dispenser
try this trick
instead of trying to get the fridge through full on or sideways
put the fridge side on to the door way then open the fridge doors first
that reduces the fridge width by the thickness of the doors and the body of the fridge can be maneuvered through the door way and turned slightly at the last bit to allow the door and hinges to get past the door jamb
You can take the doors off but you have to be sure that on reassembly the doors are sealing properly and adjusted correctly
Jan 24, 2017 | Refrigerators
Hello Philippa here, I have resolved my problem. Thank you
Hello and thank you. My Hisense fridge HR6BMFF520 alarm sounds when I open door. Display shows -88. It is not very cold inside. Regards, Philippa.
So how did you fix it? Thanks for letting us know. All posts about the same post are better done by COMMENT under the posters name :>)
Nov 15, 2016 | Refrigerators
What might the problem be and how can I solve it?
The evaporator is iced over. Simplest solution is to shut the unit off, clear all items out of it and let it sit open for 24 hours. Afterwards, restart the refer and allow to run for 3 hours and check for proper cooling in the fresh food section.
Jun 22, 2016 | Frost Refrigerators
Hisense americanfridge freezer RS731N4AC1. Can the doors be removed to fit through standard door frames.
yes the doors are always removable. Also you can open the door and swing the fridge till it will reach second door .Open second door and complete the chore
Dec 28, 2014 | Hisense RS731N4AC1 Stainless Steel 562 l...
Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Sep 26, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Inside light on fridge/freezer not working.
OK, the digital logic being out reminds me of the possibility the mother board or circuit board has gone out. If you can get the complete model number on inside of fresh food compartment door frame, near bottom of door, I will be able to help you better. While I wait I will try to look up similar models and get better answers for you. Thanks, Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Inside Dsiplay Not Always on
Hi -
I haven't solved my problem, yet, but i have determined that it's beyond my scope and will require a pro's visit to my house.
thanks for the line.
b
Aug 17, 2008 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
