Lg.MDL.32lh20r. switching problem any light on.but not standby.
    Top Expert:
  • Televison & ... Master
  • 75,025 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 17, 2016
3 Suggested Answers
  • 3 Answers
SOURCE: Blank Screen/Powers up, Power LED can be switched from ON (Green) to STANDBY (Red)
Gateway was sued Class action over LCD's and Plasmas they sold over a 2 year period. They resell 3rd party TV's that were very faulty, an immature design.
Here's what I learned about mine, which makes it limp through as a Computer monitor (both DVI and VCA) and halfway functional TV.
You have to connect a DVI source, on the Main Menu for the DVI input there is an option called "Factory Mode". scroll down to it with the CH buttons and select it with the vol button. The scroll to "initialize eprom", select and confirm it. After the "Waitting" words disappear, make sure you have a TV source connected, Then turn the TV off and on, using the hard switch in the back. The TV input should be defaulted to channel 10 or 11 now But you select a TV channel that has no TV signal on it (like channel 1 for example) , the whole TV input side will refuse to let you select it again, and you'll have a blank screen and have to start over.
That takes care of the blank screen thing Now the other problem is parental control is defaulting to "ON" or something, and you can't program channels. With the TV input Main Menu engaged, select "Setup Menu." If you have this problem, then you'll only see 2 options, all the TV input and channel programming options will be missing. You have to select Parental Control, and when it prompts you for a password hit the volume > button 4 times (or just wait for a minute.) This should bring back your TV System and auto prgram/manual search options.
Unfortunately, my TV doesn;t remember these setting very well if I select cable, it does better if I select "AIr". But at least it funtions - kind of. If you switch to your computer input, you probably will have to switch the monitor off and on from the back panel again. Mine always starts up with the menu onscreen. All this might bve less trouble if you have a the remote, I don;t know where mine went after the last move.
Good luck, and hope this helps.
Billy K.
Posted on Feb 12, 2009
  • 10 Answers
SOURCE: t.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Posted on Sep 01, 2009
When you switch on the tv it goes to standby mode, and when you press standby it turns on to a orange light then goes back to a red light, any idea whay this is happening ....
My Westinghouse LCD tv has the same lights on it It goes orange or red when there is no signal from that source... or while it is calibrating itself to the new frequency etc.
Oct 19, 2013 | LG 42PM3MV 42 in. PLASMA TV
LG 42in Class 1080p 120Hz LCD HDTV red light stays
Your tv set is stuck in the standby mode as a components went shortcircuit in one of the power supply rails and should be serviced by qualified personnel.
Sep 29, 2013 | LG 42LC2D 42 in. LCD HDTV
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
I have a new LG 32 LD450 TV. When the set is on, there is a green light in lower right. when set is off there is a red light in lower right. should this red light be there all the time, even when set if...
The red light means it's on standby mode but if you wish to turn off the red light you can just go to menu >option>power then choose standby light off.
Jan 08, 2011 | LG 42LH40 LCD TV
Wont come out of standby
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info.
Mar 08, 2008 | LG 50PX4DR 50 in. Plasma TV
The problem is most likely a defective lamp. See your owners manual on lamp replacement as this can be done by the consumer.
Dec 05, 2007 | LG RU-44SZ51D 44" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
