Question about Dyson Vacuums
My dyson 25 smells like burnt plastic when in use. What could the problem be
    Top Expert:
  • Dyson Master
  • 45,582 Answers
It indicates that the insulation for the wires is melting from overheating wires
stop using it and take it in to an appliance repair shop for an inspection and proper diagnosis
if it is still under warranty take it to an authorized service agent
Posted on Dec 18, 2016
My dyson dc28 brush stopped turning after a pop and smoked. Smelled like burnt plastic. The attachment hose still has suction and is working fine. What happened?
Hiya.
When an object gets under the machine it can
cause the brushbar to suddenly jam. The belt between the motir
and the brushbar however is forced to keep turning
causing the rubber belt to burn an then break.
Jun 01, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Smoking and smells bad
This is generally a sign that the motor has burnt out. With spendy vacuums like Dyson, it's often worthwhile replacing the motor rather than the entire vacuum.
Apr 06, 2014 | Dyson DC14 All Floors Upright Vacuum...
Cleaning my Dyson DC 23
It could be a deteriorating belt. I have a Dyson and love it, cannot think of anything that would smell but burnt rubber.
Dec 04, 2013 | Dyson Vacuums
While 1/2 way through vacuuming my carpet, my Dyson 28 stopped picking anything up and started to smell like burnt rubber. I cleaned the roller on the bottom and spun it around to check the rubber belt. ...
I'm sorry to hear you're having difficulties with your DC28. Since you've checked for an obstruction, but have been unable to resolve the issue, it's probably best if you get in touch with us directly so we can provide the support you need as quickly as possible.
You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 23, 2011 | Dyson DC28 Animal Bagless Upright Vacuum
My dyson dc07 has started to smell a bit of burning.
This will be 1 of 2 problems.
1. If its a burnt rubber smell then its the belt that has gone and will need to be replaced.
2. If its a metalic smell then your motor is burnt out.
Replacing the belt is easy enough, the motor is a lot more complicated and should be left for an expert.
Feb 04, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
On turning on different noise then noticed smell of burning then just stopped working and no power since. DC 07 Dyson.
Unfortunately your motor had burnt up..most times this is due to not cleaning or replacing the filters...the filters get dirty and the motor gets no airflow to cool it....very common on dyson vacs
Feb 07, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a Dc-25 Dyson ball,The beater bar does not spin.I pressed reset,...nothing.any ideas?
check to see if the belt is broken or loose and have a technician look at the clutch to see if its burnt out.
Oct 22, 2009 | Dyson Ball HEPA Upright Bagless Vacuum -...
Turns on, brush rotates, but no suction.
the only thing i know about vacs is if there is no suction its blocked might have sucked up a piece of plastic bag and wraped around the fan hence no air or the screw that holds the fan has come loose take your filters out and turn on you may have sucked up fluid and not known it hence filters are blocked also brushes may seem alright but may be worn under half there fore springs are not at right tentsion if your armiture is black where the brushes run on may not be getting a good contact or if it smells burnt good chance you burnt it out then theres the power switch test with multi tester the check for loose terminals then test the field coils are correct ohms as well
Jul 09, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Smoke and bad smell coming from the base
you need a nw belt but before you change the belt clean the burnt rubber off the motor shaft or your new belt won't last
Apr 03, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
