Question about CDA Washing Machines
Cda vw80 won't fill with water. Is it possible to reset?
My FAFW3511KR front load washer won't spin on the wash cycle. It has error code 11
Hello Geri Witkowski - I understand that your washer displayed E11. Typically error code E11 indicates that either the unit is taking too long to fill with water or there is a possible leak.
· Try resetting the unit by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart unit.
· Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from the unit. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
· If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
If you have checked all of the above, the unit may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Mar 18, 2013 | Frigidaire ATF6000ES Front Load Washer
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Whirlpool ultimate care ii won't spin
Possible that the drive is jammed , there is slipping or the motor is faulty. You need to check for free movement after disconnecting the power, if there is friction it must be reset.
Jan 21, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Cda 497/1 not washing
see this possible causes: Water-heating cycle the cicles compren washing, and rinse, the machine stop, because the heating element, and thermostat can be defective test.see the diagram Timer test the timer see the diagram for defective, clean contact, with special spray, tigh the wires very well. 5_9_2012_10_57_35_am.gif5_9_2012_10_57_57_am.gif
May 08, 2012 | Dishwashers
CDA WC130 integrated dishwasher partly fills with water then pumps out and beeps as if the programme has been completed
Check the sensor of the liquid at the bottom of the dishwasher. Sometimes that is the cause of the fault.
Mar 13, 2012 | Dishwashers
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Don t have a problem but i need a diagram how to wire a alpine cda-985 reciever to a kenwood kac-x542 amp in a 74 corvette
how to fit an indirect hot water cylinder from off an rayburn royal .and is it possible to use a pressure cylinder . diagrams would be useful please.
curt
Sep 22, 2009 | Alpine Car Audio & Video
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
Top CDA Washing Machines Experts
NOEL
NOEL
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
