Question about Mackie 1604 Vlz3 16 Channel Mixer
Mackie CR1604 has a consistent click at hi gain
Mackie CR1604 has a consistent click/pop at high gains for all channels. is this duw to a bad PSU
  • pjnocode96 Jul 27, 2009
    The click is on any channel that has its preamp set at greater than -10dBV with or without a signal and no connections.
  • Lawrence Nentwig
    Lawrence Nentwig May 11, 2010
    How is your gain structure usually set?
  • 4,234 Answers
Without hearing the noise or seeing it on a scope, I can't say for sure, but this type of noise can come from a number of sources. If there is a high signal level on one bus, you could be getting some cross-talk from that channel onto the channel with the higher gain setting. Try to track this down a bit by experimentation. For example, do you hear this with NO connections at all, but with the gain turned up on one channel?
Please try a few things to narrow this down a bit and I'll try to provide you with some options.
Thanks,
Dan
Posted on Jul 25, 2009
  • ABRsvcs Jul 27, 2009
    Thanks for the update. I'll check the schematic and get you some options. I'm on the road at the moment, so it may take a day.
    Dan
Why does my mackie cfx12 mkii have low output across all 8 xlr inputs at unity gain with distortion above that?
Where are you getting the low output? It would be very strange if all channels failed in the same way so it is probably something common to them all. Can you get the clip light to illuminate at all by turning the gain up on a mic channel and shouting into the mic? You are referring to the gain at the top of the strip not the slider aren't you? What happens if you assign a channel to the other sub channel, does the level come up through that? What happens if you take the output from the aux send and you send signal there, is it the same issue?
I may be completely wrong but I suspect if it is only mics that are causing a problem you may have the routing set up wrong or not set a level somewhere else right.
Aug 10, 2014 | Mackie CFX 12 mkII 12 Ch. Compact SR Mixer...
How to setup a vocals
Turn gain CCW. plug microphone in, mute the channel. turn gain CW until peak LED flashes (while singing loud!) and turn gain back a little bit.
Take the channel fader down, unmute the channel. Put masters at 0dB (near maximum) and adjust the loudness with the channel fader to what you like.
EQ: it always depends on your location. Keep it flat. You might like to reduce at about 200-300 Hz. Cut the low end (Hi Pass Filter = on) or if no HiPass reduce "bass" for about 6...10dB.
ok?
Mar 29, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
I have a mackie cfx 16 mixing board.My problem is that , the only way I can get a good signal to the led's for each channel (0 db) is to turn the gain up so high on the channel that it constantly...
No reason to worry about getting signal to the LED's... you set the trim gain so the loudess sound or signal that can happen barely clips or is slightly less. That is the starting point. Watch videos on mixer setup on YouTube. DOn't worry if their mixer is different as the principles are the same.
Mixer fadrs should be around 80% up when system is balanced. ALWAYS use BALANCED cables... eithrt XLR or TRS.
Aug 21, 2011 | Mackie CFX 16 mkII 16 Ch. Compact SR Mixer...
I have a mackie 1220i onyx mixer, but i cant get it to record vocals unless the gain is turned all the way up
What is the setup you are using. What mics (make and model). What are the settings for the channels? With this info, I should be able to assist.
Please update this.
Thanks,
Dan
Jan 25, 2011 | Mackie Onyx 1220i Onyx1220i Onyx-1220-i...
Hi, Model: Mackie 1604 VLZ PRO When using the control room monitoring, even if the corresponding "SOURCE" switch of the subgroup/main mix is disengaged, there is still small volume of sound. This is...
You may be getting a small amount of cross-talk. How high are the gain settings and sliders when this occurs? Also, can you describe the overall setup that you are using? I'll check the prints, but you should not be getting any volume unless the gains are maxed.
Dan
Oct 15, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
No volume control with 2 faders on Mackie CR1604 mixer
If all other functions work for those channels, the most likely problem is the fader itself. These can fail and operate more like switches rather than faders. Without witnessing the behavior, I can not state that for sure. While these mixers are not the hardest to work on, they are time consuming. The faders can be purchased from Mackie directly. If you need to have this repaired, any shop that repairs audio gear should be able to erpair this for you. Where are you located?
Dan
Feb 09, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
Mackie 1604 Vlz3 16 Channel Mixer Logo
262 people viewed this question
Top Mackie Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
