Question about Sebo Vacuums
My Sebo Felix whistles from the base of the hose attachment
ukvacfan
  • 328 Answers
SOURCE: sebo felix upright
Hey Debs
Ive got a Sebo Felix. Unfold the bag (if its folded) and drop it into the top of the bin. Once you've aligned the plastic parts the two nibs which are pointing outwards towards the handle, make sure the plastic collar is sitting on the rest of the surround.
Now the most important aspect is the plastic flap - not the dust cap - but if standing behind the Felix, there is a green flap on the left hand side of the bag which must be pushed down over the spring (looks like a large staple). Once that is folded over and locked in, the lid should close. If the lid still doesn't close check that the top hose fitting has been securely locked and is dust free. Dont forget to rate, ty.
Posted on Jul 26, 2008
  • 389 Answers
SOURCE: my sebo felix is completely dead - i have checked
Most likely this is a problem with the flex. Quite often it gets damaged (simply wear and tear) - most commonly just where it leaves the plug or where it enters the machine, as these points are subject to the most strain and flexing. Unless you feel confident dealing with electrical problems, you are best advised to let a professional repairer look at the machine.
If you want more help, post a reply here, and I'll see what I can do. Good luck!
Posted on Mar 15, 2010
  • 389 Answers
SOURCE: Sebo Felix Premium Vacuum cleaner brush will not
Just the other day we had a customer bring a Felix in to our repair shop with the same problem. Although she'd had the Felix for several years, she'd never realized that one of the buttons on the base is a foot-operated switch (the left hand one as you see it from behind the machine). Hers had been "on" from day one, and never been switched off... until she'd obviously inadvertently pressed it without noticing and switched it off. Then she thought something had broken.
It may be as simple as that. So, does the green light come on when you operate the foot switch? If it does, and the brush doesn't spin, you have most likely got a problem with the motor (or possibly the circuit board) in the base. If the green light does not come on, there is most likely a poor (or broken) electrical connection where the bag compartment plugs in to the base.
I'll gladly try to be more help if you want to post more details.
Posted on Jul 11, 2010
SOURCE: top motor does not work
Your Sebo Felix needs to have a new suction motor fitted. I had the same problem with mine when it was only nine month old.
Posted on Jan 21, 2011
small6363
  • 18424 Answers
SOURCE: sebo felix belt is broken,taken screws from bottom of vacum but will not come apart
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment..
Posted on Oct 14, 2012
My sebo felix cut out while in use and won't switch back on. I've checked the fuse and cleaned out the bag and hose ect and it still won't work.
They are known for the cable to break internally where they go into the machine. It's a simple repair for any vacuum repair shop.
Sep 20, 2016 | Sebo Vacuums
Why will my sebo felix not turn on when it is plugged in. The bag is empty and the beater bar is free of threads and string.
If it is only the power head that does not turn on, make sure that the hose is fully inserted into the bag housing. There is a switch in the bag housing that has to be activated. If you are not getting any power anywhere, the most common cause would be the power cord. If you are getting 120 volts through the cord, you may need a new power switch. I have included a parts list for your machine for reference. http://sebo.us/pdfs/website_schematicsPDFs/FELIX%20Schematics.pdf
Aug 06, 2014 | Sebo Vacuums
Sebo upright barged hoover- good suction using hose, brush wont turn, sounds fine when running, nasty wineing noise when stopping?? help!! i love my hoover, have checked for bolckages....
The real clue seems to be the brush is not turning, a bad belt is possible or a blockage at that head, if you cannot get the brush moving the rest does not matter.
Dec 03, 2012 | Sebo Felix Classic Bagged Upright Vacuum
Sebo felix belt is broken,taken screws from bottom of vacum but will not come apart
Oct 13, 2012 | Sebo Felix Ice Blue Bagged Upright Vacuum
Top motor does not work on felix sebo
Jan 08, 2011 | Sebo Vacuums
Sebo Felix Premium Vacuum cleaner brush will not spin. Not the belt, already checked.
Jul 07, 2010 | Sebo Felix Classic Bagged Upright Vacuum
Sebo felix upright
Hey Debs
Jul 25, 2008 | Sebo Vacuums
Vacuums Logo
51 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
