The water not draining out the machine after end the cleaning processes
    Dedicated:
    Visited the website for 20 consecutive days.
  • 341 Answers
Did it do that before ? It may need to manually advance to spin cycle.
However, if it just stopped pumping, does it sound like the pump is trying to remove water ? Very common problem is a blocked filter, usually a small panel at bottom of machine at the front. Open panel then twist out/unscrew/unclip (whichever type it is...check manual) and examine filter. Make sure you have large flat pan to drain water into !! you will need a mop.
The pump itself could be burnt out, common too.
Posted on Dec 17, 2016
Why is there standing water in the drain pipe?
shouldn't be any water in the drain pipe. at any time actually. You might run a snake down the pipe and try to free up whatever is obstructing the water from flowing out. A washing machine drain pipe is usually connected to your sewer. but in some cases it may run out into the yard somewhere. If this is true in your case, your obstruction may be at the end of your drain where it flows out. Good luck!
Jun 20, 2015 | Washing Machines
Will not spin
First unplug the machine.Check the drain hose between the tub and drain pump for debris. Some drain pumps have clean out basket attached to them. If yours does open it (prepare for water) and dump the debris then see if you can reach the impeller with a finger. Make sure it turns (it won't spin but you should be able to turn it with a finger) and is not wobbly or cocked to the side. There will likely be some debris in the hose from tub to pump remove it and shine a flashlight into the hose. Look in the tub to see if you can see the light. If so hose is clear. If not there may be a sock or something stopping water from draining properly. Once you are satisfied hose is clear and pump is functionable, plug the machine back in and give it a try. Good luck.
Jan 12, 2013 | Washing Machines
GE gtwn5050mows water spitting while filling
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
http://www.espares.co.uk/advice/washing-machines/a/7
May 17, 2012 | GE Washing Machines
Not draining and check water light on
you have a blockage in drain pump consult manual for cleaning process when water drained away check water light will go out.
May 27, 2010 | Bosch 24 in. SGS43C12 Classixx...
My Whirlpool Ultimate Care II will not fill up with water.
ck drain hose end of hose should be at least 30-36 inches from floor also end of hose needs to fit loosely in standpipe ..if drainhose is too tight siphoning will occur
Dec 21, 2008 | Whirlpool Ultimate Care II GSW9650LW Top...
Utomatic washing machine cannot drain the water
see if theres not something clogging the pump on ht e machine
Nov 02, 2008 | Washing Machines
Whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
