Paper jam in out {stationary paper} - Office Equipment & Supplies
Error code 5102 on konica minolta c253
According to the service manual, Code: C5102 Code C5102 Description Transport motor's failure to turn
• The motor lock signal remains HIGH for a predetermined continuous period of time while the motor remains stationary. Remedy 1 Check the M1 connector for proper connection and correct as necessary. 2 Check M1 for proper drive coupling and correct as necessary. 3 Check the PRCB connector for proper connection and correct as necessary. 4 M1 operation check. 5 Change M1. 6 Change PRCB.
The technical sites say that there is probably a paper jam. If the jam is cleared but the error persists, the transport motor will probably need to be replaced. This motor has a pretty high failure rate. A qualified copier technician should be able to change it out in 30-60 minutes.
Aug 30, 2015 | Konica Minolta Office Equipment & Supplies
Hi, stationary jam indication with no error code in canon irc3170; why it shows like this. Can enybody help me.
check paper pice in the paper feeding unit and chech p f unit sensor switch may be broken
Nov 20, 2014 | Canon Office Equipment & Supplies
Jam 0205 in ir5000 canon machine. Please give me
there could be a small piece of paper stuck wehre the vertical path sensor is. it is showing a stationary jam at the vertical path 3 paper sensor. there is more than likely a sensor that has become wedged or has a piece of paper holding the sensor closed instead of open in or around drawer #3
Jun 11, 2010 | Canon imageRUNNER 5000 Copier
Error 9343
Wait please.FF: Types of Jams
T04-201-01
Code Type 00xx none 01xx delay jam 02xx stationary jam 0Axx stationary jam at power-on 0Bxx front cover open jam
Mar 13, 2010 | Xerox DocuColor 12 Color Copier
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
My 2270 jambs paper from tray one every time. I changed the pickup rollers still no help. All my other trays feed properly even the stack bypass
Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation 0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint adheres to surface of vertical path roller
Description
Since a type of paper that can easily generate lint was used, the paper lint adhered to the surface of the vertical path roller and decreased the paper feed performance of the roller, causing the jam code "0105."
Depending on paper sources, the following jams occur.
- Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10 delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
- Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2 (cassette pedestal) delay jam)
To prevent this, a vertical path roller to which paper is hart do adhere was used for the following machines (the color of the roller was changed from black to gray).
- iR2230 120V THF03592 and later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606 and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596 and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439 and later/230V KFR02186 and later/230V CA SKQ01030 and later Field Remedy
When the symptom occurs with the machine without the foregoing serial numbers, replace the vertical path roller.
Kindly rate me !!!!!!!!thank mate.
Sep 23, 2009 | Canon imageRUNNER 2270 Copier
HP 2840 Jam in Print Paper Path
There are 2 primary paper sensors. One is the registration sensor where the paper feeds in, the second is associated with the fuser unit.
The first sensor is located under a cover under the transfer unit.
i) Open the door
ii) Lift out the transfer unit (Q3964A)
iii) Locate the black plastic cover plate with a small green flap in the centre. This assembly is directly under where the transfer unit was installed.
iv) There are 2 shiny screws that secure this cover plate. Carefully remove these screws.
v) Lift out the black cover plate by lifting the left section up first which allows the right section to come clear of gears.
vi) Check for paper obstructing the small movable lever under the cover plate.
vii) To reinstall the cover plate, insert the right hand side down first and line up with the mounting holes.
I can supply photos if required.
Jan 10, 2009 | Ricoh Aficio 250 Copier
More than piece it gets jammed
The problem is generally associated with the pickup roller ( roller that rotates and pulls the paper from the tray ), and the separation pad, ( a stationary cork like material.) It sounds like you need to replace both.. The concept is like wetting your two fingers to separate pages, except in this case it is a cork base and roller that do the work..
You can alternately try to rough up the cork very lightly with sand paper, and clean the roller. The pick-up roller should have some slight ribbing, and if it is all gone, a new roller is necessary. As a temporary fix is just that..temporary.
Nov 19, 2008 | HP PSC 1610 All-In-One InkJet Printer
My kyocera printer has two input trays with different stationary. The problem occurs when tray 1 runs out of paper, it defaults to tray 2, thus using the wrong stationary. How can i disable TRAY 1 from...
go to installed printer location, right click on your installed printer, click on properties you will find the paper source there and change it accordingly.
Oct 21, 2008 | Kyocera Office Equipment & Supplies
26 people viewed this question
k24674
