Question about Doro Cell Phones
How do I switch the power back on. It is fully charged And was working until I mistakenly switched the power off .model number dsb-0010. I have had it about 2years and it has been great
techman
  • 3130 Answers
SOURCE: Receiver shuts down and will not turn back on untill you unplug and plug back in
Nope. sorry to burst your bubble but your problem is pretty common on this unit. Its bad capacitors in the power supply and probably not worth repairing in a repair shop. since this is a solid state reciver, there are no user replaceable parts inside.
Posted on Sep 24, 2006
SOURCE: jvc gz-mg330ek--will not power up--will not switch on
hi.
thank you for your email.
i have since sold the camcorder on--no more problems with it.
best regards
mr.j.b mc dermott---brunhouse.
Posted on May 29, 2008
SOURCE: Dimension E510 LCD Monitor with broken power switch
Thanks for responding. Nothing happened when you pressed in the power button and the warranty had expired; Dell was no help so don't bother. I read that there were tab(s) on the plastic power button that had broken off and no longer engaged the power switch. I "solved" my monitor problem by drilling through the plastic case between the power button and the minus button, pulled out the plastic power button and pressed the switch with a flat screwdriver to turn on the monitor. Now I leave the power on all the time and put a piece of black masking tape over the space where the power button was. Not the best solution I'm sure, the hole isn't pretty, but it works. If anyone else wants to try this solution be careful when you drill through the plastic case because the switch you want to engage occupies the space between the buttons, exactly where you are drilling. If you drill through the switch you might as well throw the monitor into the recycle bin. I expected to find an actual button switch and was surprised to find a flat, 2 prong circuit switch instead. Good luck to all.
Matt
Posted on Sep 18, 2008
  • 4 Answers
SOURCE: Wont turn on after fully charged.
There was a whole series of GMT800CS trimmers which seem to have had defective rechargeable batteries. I changed the ones in mine after a similar problem arose and it works fine. The instructions on how to get to the batteries are in the manual which is supplied. You will need 2 AA NI-MH batteries, but I do not recall if they were the type with tabs or not. You can buy the ones with tabs at Radio Shack. Hope your problem is the same and I am almost sure it is.
Rom
Posted on Jul 11, 2009
rcalorisian
  • 313 Answers
SOURCE: Battery fully charged, icon says fully charged but
sounds like you "MIGHT" have a bad battery. But before you go shopping try to reset you battery..
  1. I have had the same problem and emailed Acer. You need to upgrade your BIOS settings and it will be fixed. www.acer.com.au/helpdesk
    This was acers response:
    Dear customer,
    Recently it was identified that a small number customers were experiencing a problem with the battery where it would not hold a reasonable amount of charge. We have released an update that should be applied to your computer to resolve this issue. Please complete the processes below and should you have any problems please do not hesitate to contact Acer support on 1300 365 100 or log a service request online at www.acer.com.au/helpdesk.
    Thank you, Acer Support
    THey also sent me a word doc with the process and a zip file with the BIOS update. I can not upload the up on these forums but if you go to acer they should respond within 1 hr. I sent my request at 1700hrs on a Sturday afternoon and got a response within 40 mins.
    ** if you need help with that then, this is how you do it. **** After download Acer Aspire one – battery not charging.
    Solution: Update the bios as follows:
    1. Go to www.support.acer.com
    2. Click on Driver & Downloads
    3. Select Product Family “Netbook”
    4. Select Product Line Aspire One
    5. Select your Product Model i.e.: AOA150 (located after MFG.Date:xxxx AOA 150 – xxxx)
    6. Click on the BIOS tab below
  1. Just a little more information on the Acer Aspire One Battery not charging issue:
    BIOS revision 3309 (and later) has a fix for battery charging particularly the 6-cell batteries, however if you have the latest BIOS and your battery still isn't charging a good solution is to power down the computer, remove the battery and unplug the AC power cable then push and hold the power button for a whole 2 minutes (nothing will happen, we're trying to completely drain all residual voltage from the mainboard to reset it), then release the power button, install the battery and power up the computer, it should now recognize the battery and begin a normal charge cycle.
    I have read other posts that claim to hold the power button in for 1 minute which I tried and it did not work, you must hold it in for the whole 2 minutes. (which is probably what you were advised to do,as you mentioned.I just like to cover all the bases,)
I know it is a lot. But I hope it helps
Posted on Oct 27, 2009
Testimonial: "So helpful,thanks will try this first- saw other posting bout 'BIO', Acer said hold for 30 secs- then post back under warranty- not keen"
Correcting Canon Error E00004-0010
Enter service mode.*28* go to function.then go to reset error activate press OK. Power on or off. If it returns you have a warm up issue. Either the thermistor ,thermal fuse,lamp or lamps depending on the model.or the thermistor is got something between it and the surface of the roller or broken upper fused roller bushing depending on the model. Now the 010 means that it has been turned on and off with out a reset completion. Good luck Heat issue. What's the model?
Feb 02, 2015 | Canon Office Equipment & Supplies
How does your rotary shaver model number H5010BK not change colour of the led display when fully charge seems to stay red and I have charged it for eight hours
How old is it? I ask as if the batteries are past their best, they can get to the point where they never actually take a full charge.
Try cycling the batteries. Once charged, turn on the razor and leave it on until batteries are completely flat. Do this in one go without switching it off. Then re-charge for 12 hours and see if this resolves your problem. If it doesn't help, and razor is older than 3 years, then you may need to replace batteries.
Nov 26, 2014 | Health & Beauty
My notebook was working fine the day before, and fully charged! today, while attempting to switch it on by sliding the power switch, it won't happen! it is not switching on! please suggest how i may f
Probable cause. Plastic on/off power switch slider is cracked and cannot operate actual power switch. Need to disassemble netbook to gain access to switch. Superglue may provide temp solution but best option to contact Samsung for part.
Dec 22, 2011 | Samsung N150 (36725723009) Netbook
I am trying to use my start-it pro system for the first time to jump start my vehicle. Can someone please tell me where does the power connect to the actual 12 volt dc supply. I have 2 things 1. The yellow...
When a question is presented to any forum, model number(s) are essential. Please provide any that you have and if you would. Just to make sure I'm fully understanding what you're asking, would you please rephrase your question?
A lot of models don't come with an AC/DC wall charger and it must be purchased separately but I'm fairly certain there is an alternate method to charge your unit. I'll be able to specifically determine how, once I have the model number.
FYI: The VEC070 1.5 Amp Automatic Charger is a commonly used charger for this type of jump-start system. Don't buy anything until we're certain.
Sep 08, 2011 | JUMP START SYSTEM
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
New Bigfoot toy for XMAS buzzes three times and stops working. Reset with power switch and does the same thing repeatedly. Made sure battery was fully charged.
There is a pen hole beside power switch........with the power off press and hold this button (with a safety pen or something)....while holding the button turn it on and hold the button for at least 3 seconds. Then push every button on the remote, then charge the battery until the indicator is "green". That will fully reset your Bigfoot.
Jan 02, 2011 | Mattel Fisher-Price Imaginext Big Foot
My Sony Vaio battery light remains orange
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 26, 2010 | Sony VAIO Notebook
TomTom GPS 1xl on/off switch does not work When I press On/OFF switch, it does now start. When I put for charging, LEG glows.
leave the device to fully charge then try it , if the internal battery is flat you wont be able to do anything untill you put power to the device
Mar 09, 2010 | GPS
Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Nov 16, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
Cell Phones Logo
Top Doro Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
terry stevens
Are you a Doro Cell Phone Expert? Answer questions, earn points and help others
