Question about Cell Phones
We have LCD Projector DVM-G90M (DONGWON) When turn on the unit the blue color is appear, after welcome display the blue is change into yellow display, Whats going on Please.?
Please for help.
Kimi
  • 277 Answers
SOURCE: MT830 Color Convergence (Blue Left - Yellow Right)
take a look here: http://www.extremetech.com/article2/0,1697,1049289,00.asp "... The others, however, have lost portions or all of their blue channels. TI's theory is that the shorter wavelength and higher energy of the blue light apparently causes the organic polarizing material in the LCD to get lightburn much faster. TI showed us a damaged LCD panel that controlled blue light transmission, and there was a large spot in the center that was apparently burned out..."
Posted on Oct 31, 2006
Marrie
  • 563 Answers
SOURCE: LCD projector has a 'shadow' in the green color
This is a Mainbord problem , the lcd would have shown blotches on your imagr rather than a shadow effect.
Posted on Apr 21, 2008
anjana03
  • 361 Answers
SOURCE: LG - L192 WS LCD Monitor displays blue color
it isnot softwere problem. we can not solve in home. lcd graphi can be reset.which we can get in net it can be solved by expert. once atime i get it in web side, t
Posted on Jun 15, 2009
timothypeacy
  • 23 Answers
SOURCE: Projector displaying yellow tint in center of screen.
The yellow tint is probably coming from the lens. It could be that the glass is tempered or possibly just needs to be cleaned.
Posted on Jul 24, 2009
SOURCE: My TEAC PL-D2100 home theatre system, is not showing all natural colors in display since yesterday.
When I play a DVD on my TEAC PL-D2100 a box with no signal comes up? And a countdown begins. I can hear the dvd through the speakers but no picture? Any ideas
Posted on Sep 27, 2009
Sanyao plc-xe31 displays yellow
the Blue Lcd panel was broken, the price of the panel is USD80
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mar 16, 2012 | Sanyo FOR PLC-XE31
Sony VPL-HS50, any viewing (TV, DVD) a spread of blue appears on various parts of the screen, generally contained to the sides but from top to botom. Just recently a large yellow blotch appeared in the...
If this projector is an LCD (liquid crystal display), your LCD probably gone.This usually happens after a period of time with an LCD projector.Try cleaning the LCD or take it to your Sony dealer. yours faithfully Zkhan
Jan 30, 2010 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Yellow tint
Hello. Here's the visual key to remember about projectors--LCD panels show their colors like this: RED lcd panel displays cyan onscreen(baby blue); GREEN lcd displays purple; BLUE lcd displays yellow. ( You now know where the displayed dust is!) The problem is most likely a burned blue lcd or polarizer filter in front of the blue lcd panel. This occurs when the dust filter isn't cleaned regularly or properly and heat builds up--yes, enough to "cook" the lcd panel or actually cause a burn to develop on the polarizer. The polarizer is just like a lens in a pair of good sunglasses. It is a small, extremely thin, pane of glass with polarizer material glued onto one side. When burned, it causes a "shadow" effect--that enhances the display of that particular color--in this case, yellow.--Hope I was of assistance!---Rick
Dec 30, 2009 | Panasonic PT-AX200U Projector
Dell 2400 MP DPL Projector projects a yellow tinted image.
Clean any external dust filters or air openings in the unit.If you don't want to remove the filters, you can simply use a vacuum cleaner hose to suction away the dust from the filter element--same effect anyway. The unit probably does indeed need a thorough cleaning.
The yellow effect is most probably a burned BLUE polarizer filter located behind the blue LCD panel. (Color key--Purple onscreen=green lcd, baby blue onscreen=red lcd, and yellow onscreen=blue lcd). That's how you can tell which lcd has dust on it! Usually, the green lcd has the most free area around it and collects the most visible dust. (large purple specs) The polarizer filters can get burned due to excessive heat (not keeping proper ventilation). Of course, it might be the blue LCD panel which is failing prematurely due to heat build-up over time. The polarizer filter isn't that expensive if it can be replaced, however, the actual lcd panel IS.---Rick
Sep 07, 2009 | Dell 2300MP Multimedia Projector
Same problem w yellow on viewsonic pj550
Yellow is the mixture of 100% red and 100% green. what you may have here is a blue LCD failure in the machine. Try this to check. Open up PAINT and double click one of the colors on the bottom. now click add custom color. then in the RGB section put 0 for red 0 for green and 255 for blue. ok out of everything and fill the background w/ the blue. it should be a VERY intense blue, if its white or or kinda blue, you have an LCD issue
Apr 13, 2009 | ViewSonic PJ550 Multimedia Projector
Faded color display
replace the colorwheel.
Jan 27, 2009 | Eiki EIP-3500 DLP Projector
Yamaha LPX 510
Welcome to the disapointing world of LCD projection. Your blue device is dying and thus allowing the green to come through instead of combining for white. I suggest buying a dlp product they are immune to this color decay problem. Good luck
Jan 13, 2009 | Yamaha LPX-510 Multimedia Projector
Color Problem
I think that projector used three different LCD panels with red, blue and yellow. You probably have a damaged red LCD panel, and if so, it is not worth getting the projector fixed. Those panels were really expensive back then.
I once had that red problem with a projector and it turned out to be a bad connection on one end of the "computer to projector" cable. Borrow one from a friend and see if it solves the problem.
Mar 23, 2008 | Office Equipment & Supplies
Projectors screen turns yellow,on and off,after awhile has been looking white
You are describing Color Decay. Welcome to the world of LCD projectors. The blue device is the first to go, thus the yellow fringe. You must have about 3-4000 hours on the projector. Replace the product with a dlp product and it will last a lifetime, or until you want something with newer features.
Mar 06, 2008 | Sanyo PLC-SU50 Multimedia Projector
Benq 7220 display wrong color
It sounds a lot like a bad color wheel if it was a DLP. IF it is a LCD then i would say one of the LCD panels is bad or possibly a connection problem that drives the panel or the connection that hooks up to the projector is suspect. Let me know if that helped you at all.It is strange that the bottom shows white though. Jay
Jan 30, 2008 | Office Equipment & Supplies
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
