Question about Home
What is the way of removing dried white cement from tiles?
3 Suggested Answers
  • 22 Answers
SOURCE: Tile over a cracked cement floor
You can get a crack membrane to put over the cracks. First use a primer on the floor, this is a primer just for this application, then put membrane on top of primer. these products can be found at home depot or lowes or any tile store.Also do not use cheep thinset. the better thinset is more flexible and will absorb any movement. The cement board would not work as they will move or flex and cause the grout to crack and tile to loosen
tom
Posted on Dec 13, 2008
  • 246 Answers
SOURCE: Walk-in shower floor problem
They probably use wrong adhesive that is not hard yet and have tenedency under pressure to squeze out between grout lines. Yes they need to address the problem immediately.
Posted on Feb 13, 2010
What tiles are used for living areas?
That totally depends upon your personal tastes, and whether your subfloor is strong enough to handle the movement. The larger the tile, the more solid your subfloor needs to be. Moreover, NEVER lay ceramic or stone over tongue and groove hardwood floors .. far too much flex .. and don't buy into the "well .. we lay fiber cement board .. " Fiber cement underlayment does NOT add to stability or structural integrity.
So, what type of tile do you want? Then, it's beefing up your subfloor .. to accommodate. Add underlayment, thinset and set .. grout the floor and you should be good to go.
Apr 04, 2017 | Saws
How to remove cement glue from old floor tiles to reuse tiles
That's part of the problem of removing adhesives; it takes a while.
You can try a stronger solvent but you can risk damaging the tiles. Also make sure to use proper protective gear and ventilation if you do. If you are going to stick to the method you are using now, try letting them soak longer with a stronger mix of soap, or TSP; you can scrape if you use a stiff plastic putty knife.
Mar 21, 2015 | Ceramic_Tile_Treds Building Materials
Where does the rubber membrane go when tiling a bathroom floor
tiles on wooden floors will always move and crack the grout/tiling cement
therefore the rubber membrane goes down first with out nails and then everything is laid on top
that way when the wooden floor moves , there is a water proof membrane to prevent the water from rotting the wood over time
Jun 14, 2017 | Home
We are staying in a rented home with a spa bath. Attached to the spa bath is a hand held shower. The showerhead rests above the bath but the pipe coils somewhere between the tiles and the bath and can be...
The grout between tiles is just for filling the gaps. The tiles are glued to the wall, usually with "thin-set" mortar. Unless that mortar is in very poor condition it is unlikely that you would be able to remove that single tile without breaking it. The wall behind the tile might be water-resistant drywall (a poor quality situation) or it should be cement-board. I suppose it's possible that there is already a hole in the wall behind the tile, but the hole would be smaller than the tile, and assuming 4 inch (not large) tiles, this is a poor choice to gain access to the pipes. The usual access is through the wall from the other side. During initial construction, a removable access panel is sometimes provided (depending on local building codes and whims of the builder). If there is no access panel, and the other side of the wall is drywall, then cutting a generous hole, and fashioning a plywood panel (with trim around the edge to cover the gap between the drywall and the plywood) is a pretty standard and simple approach (depending on your skills). As an alternative and for more info, here's a link describing how to install a plastic snap-in access panel. Good luck! http://www.diylife.com/2008/06/23/plumbing-access-panel-installation/
Jun 01, 2011 | Home
I bought a maax shower base. i am going to intall a cement board on the wall, water proof it and then tile over it. The shower base has a flange that is 1/4'' thick. do i install the cement board on top of...
There are two ways that I would do it depending on the width of the ledge on top of shower base. If you have enouch room I would shim studs with strips of material thick enough to bring the surface out even with flange on shower base. Then I would put cement board(wonder board) on wall and over shower flange to set on top of shower base. Finish seams on wall board per manufacturers directions,Let seam filler dry then seal with thompsons water seal or equivalent sealer. Let that dry then tile on that grouting and sealing with quality caulk at joint between shower base and tile.
If ledge on shower base is not wide enough then I would place cement board directly to studs then use filler strips on face of shower base flange to bring two surfaces flush. Water seal let dry and tile again coming down over top of shower. Grout and caulk to finish. P.S. I would use a siliconized latex emulsifier to mix in with grout. It gives a better ware proof seal. Hope this helps you. Good luck and thank you.
Jan 30, 2011 | Maax Acrylic Base for Shower - 102623
Can ceramic tile be installed over old ceramic tile?
You can install tile over tile. However here are the risks. The new tiles will require at least 3/16" of tile adhesive UNDER the tiles when put in place after they have been pressed into position. Additionally the trim around the tiles willhave to be removed and elevated the distance of the tile thickness and the 3/16" grout distance. The tiles if on the second floor of a home will easily losen due to the expansion and contraction of the home and the difference in the 2 types of tiles expansion and contraction rates.
It is not difficult to remove old tiles. You use a flat bar type scraping tool and the old tiles usually will pop right up off the floor. You will have to break maybe 2 tiles to get started but after that they are easy to remove.
My experience in my own fully tiled in all rooms 2900 sq ft home in the tropics is that I have to remove the old tiles as over time the new tiles losen on top of the old tiles. I have tried it several times and have had at least 1 tile come loose each time.
Thanks for choosing FixYa,
Kelly
Oct 05, 2010 | Home
Jan 14, 2010 | Home
Listello resin 3 by 12 : tile;white grout stuck on the tile
yes, you should seal all tile with a 3-5 year sealer. there are many brands to choose from. excess grout should be removed with a sponge and water before it dries. clean food splatters with any safe kitchen cleaner.
Jul 31, 2009 | Daltile Bathroom Accessories Resin Soap...
tom
Nov 13, 2008 | Mk Diamond 154861 MK-100 7'' x .060'' x...
Home Logo
66 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
