Blinking only when it is turned on and want turn off with the remote having to unplug it .
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
The power light is constantly blinking in yellow. before this happened the yellow light was on without blinking I turned it off, once I turned it back on the light turned green but the screen...
try unplugging your t.v for 10-20 seconds. plug it back in. if your power light continues to flash your t.v is the issue. you should be able to google your issue or check your owners manual about the problem. unplugging the t.v is the last ditch effort. Good Luck!
May 18, 2011 | Akai LCT2715 27 in. LCD Television
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Left tv unplugged for a few months no tv won't turn on
The first thing to do is try to turn on the set with the remote and then when it doesn't respond go to the set and hold down the MENU and INPUT buttons at the same time until the power LED starts blinking a two sequence code. Like 2 - 4 or 1 - 2. The code will keep blinking for five or six times and stop. The blinking is the microprocessor telling you why the set is not working. We techs call that a self diagnostic function. Which this set has. Just repost your findings.
May 27, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
