Question about Sanyo Heating & Cooling
Sanyo split units stops wans is start running I want to what's the problems
3 Suggested Answers
  • 415 Answers
SOURCE: aircon split unit in summer start up ,condensor
Check all your wires and connections of your condensor fan. If there are damaged or overheated wires or connections, correct them. Make sure connections are tight.
Check for "play" in the motor shaft. Hold the tip of the shaft and try moving it side-to-side in all directions. If there is any "play", the bearings are bad and the motor needs to be replaced. Up-and-down play is not confuse that with side-to-side play.
When the motor first locks up, while running, try turning by hand (BE CAREFUL). If the motor is tight, the bearings are bad. You might be able to buy a little time by oiling the bearings, but once they lock up, they generally will remain troublesome and need replaced.
Also make sure the condensor coil is clean.....wash it off with a hose.
I hope you find this information to be very helpful to you as a solid jumping off point moving foward. :-)
Posted on May 19, 2010
  • 4 Answers
SOURCE: lg split ac outdoor unit delayed start
acctullly when indoor unit on then outdoor unit take 3 to 5 minut taking on.
and secondly when indoor unit regain its temoerature as we set on indoor ac then it trips the out door unit.
when 3 to 4 degree exceed the temperature then it again start the outdoor unit.
reply if u understand
Posted on Jun 09, 2013
Air con starts functioning by itself.
If this is a multi split (one outdoor unit), it sounds a faulty controller board in the outdoor unit.
Nov 03, 2014 | Sanyo Heating & Cooling
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
Error c5
C05 error indicates no communication between indoor and outdoor units and remote control. Replace the remote batteries with fresh duracells first. If that doesn't fix the problem, verify the indoor and outdoor unit are wired together properly. If still no love, a tech will need to come visit. CALL SANYO TO SCHEDULE A TECH IF NEEDED. Mini-split units are new to the industry, and not all HVAC techs are good at fixing them.
Mar 30, 2014 | Sanyo Split System Air Conditioner
Hello We just installed a Sanyo KHS1271 mini-split
The condensate drain line was not properly installed. Make them pull the wall unit and correct the problem.
Be persistant until you are satisfied they have the problem corrected. Do not pay any additional money. If they do not correct the problem then report them online to the state board of heating and air. Fill out their requested complaint form and follow thru with a second complaint if you do not get total satisfaction from the contractor that installed the unit.
Hope this helps.
Sep 23, 2011 | Sanyo Split System Air Conditioner
My mss15 unit no heat right mode engaged unit starts but only cold ,both in & out units running
Have you tryed re setting The POWER to the unit??? works for me :) annoying but it works....
Aug 24, 2010 | Sanyo 24KS32A Cool Mini Split Air...
Our Sanyo split air system does not take out the humidity. What is wrong?
Is it blowing cold air.? Depending on your temp. settings will really control the humidity also . try setting it for 64 and see if that helps
Aug 10, 2010 | Sanyo Split System Air Conditioner
Sanyo split high pressure side tube icing
ok, on these units, if by high side line you mean the small tube going from outside to inside, that tube is actually on the low side, the metering device is in the outdoor unit. If you shut the unit down, let everything thaw then restart and find that small tube is freezing up right at the outdoor unit right away, my guess is its low on charge. I see that you put some in, make sure it is the right knid of refrigerant. they do not hold alot. Where is your suction pressure running. If you put 2 to 3 pounds with no change, you may have overcharged but that is telling you that there is a restriction in the line inside the outdoor unit, probably the filter if it has one, or the metering device itself. Let me know what you find.
Jun 16, 2009 | Sanyo Split System Air Conditioner
Compressor not turning on
is the compressor actually turning over ?? if not check the contactor, or capacitor is actually ok...
if it does turn over, are the stop valves open ??
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
