Question about Amana NED7200TW Electric Dryer
There is a code on my amana dryer, model number
There is a code on my amana dryer, model number NED7200TW that is not in the book can you please tell me what it is and what to do to correct this problem. The code is "[]" It looks a a capital C and then a reversed Capital C
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: I have replaced the thermistor
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Amana dryer, (as you may or may not know this model is built by Samsung) and it is displaying a e5 error (actually looks like a e5 error, but it is indeed t5 but that's because of the digital display)...it is actually a "temperature sensor" error, hence the "ts".
As described in the service manual from Maytag...
"tS" Dryer Thermistor Short Sensed - The Thermistor resistance is very low.
Check for:
Clogged lint screen. (remove and wash under hot water & mild soap...a old toothbrush works well for scrubbing)
Restricted vent system.
Check Thermistor resistance...10000 ohms @ 77°F/25°C
If you've replaced the thermistor already, that leaves either poor air flow due to clogged lint screen or clogged exhaust somewhere else along the line. Here's what I would suggest you try. Remove the lint filter (clean it as mentioned above) and unfasten the vent from the back/side of the dryer, whatever the case on your machine. Run it through a cycle without a load and post back with the results.
I can send you the service manual if you think it may help you move forward,(It says Maytag, but those are Amana/Samsung as well) but you'd need to provide an email address for me to attach it to. It is a "pdf" and 9.9mb in size.
I'll watch for your reply.
Regards,
Macmarkus :)
Posted on Jul 30, 2011
heatman101
  • 43501 Answers
SOURCE: amana dryer NED7200TW quit heating, it appears
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
I keep getting an error code that looks like 2 C's. The dryer is still drying but it will finish and shut off and then turn back on. What does this mean?
Amana NED7200TW Technical Information - ManualsLib
www.manualslib.com > Brands > Amana Manuals > Dryer > NED7200TW
View and Download Amana NED7200TW technical information online. 27" Domestic. NED7200TW Dryer pdf manual download.
Aug 05, 2015 | Amana NED7200TW Electric Dryer
My amana dryer model ned7200tw runs good but no heat
check element, termo fuse (top side of element casing) and electric box as it can run with one side (117 Volts) good and one bad..
Jan 05, 2015 | Amana NED7200TW Electric Dryer
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
I have an Amana dryer model # NED7200TW that will not power on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
How to do you take out the motor in this dryer, and put in a new motor? I don't have a manual.
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dryer-Parts/Model-NED7200TW10/1268/0151200/W0712022/00002
As you can tell from the parts breakdown it is pretty easy to do, Suggest you take a digital photo before you disconnect anything so you have something to refer back to when you put thing back together.
Jul 13, 2011 | Amana NED7200TW Electric Dryer
My dryer is an Amana #NED7200TW and I got a code HE on the display panel and there is no heat coming out. We tested the heating element protectors and they were fine. What could this mean? It is not in the...
HE shows up because there is no heat . Check the fuses in the panel and the heater itself. Also could be the sensor is not working to tell the control to turn the heater on.
Oct 29, 2010 | Amana NED7200TW Electric Dryer
My dryer will start and run for about 5 minutes than stop with code HE what should we do did everything stated in manual
Look in your owner's manual to find out what the code is trying to tell you is wrong; then get back to us.
Jim Hart
Jun 14, 2010 | Amana NED7200TW Electric Dryer
Amana NED7200TW Electric Dryer Logo
203 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
