Question about Dewalt Saws
Clean contents battery dewalt reciprocating saw
    Novelist:
  • 170 Answers
CONTACTS???? need more info--what's wrong??
Posted on May 05, 2017
  • 313 Answers
SOURCE: Dewalt DW303 reciprocating saw
go to www.dewaltservicenet.com look for the icon find it now.enter the model # of the tool & search
Posted on Sep 19, 2008
rowdy45176
  • 2176 Answers
SOURCE: Change blade on Dewalt DC385 XRP reciprocating saw
The button is for changing the shoe position, you should find a lever on the opposite side that you need to lift up on to release the blade. You might be able to get a owners manual at Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will direct you how to download one. Let me know if you need more help
Posted on Mar 22, 2009
SOURCE: Reciprocating saw stops reciprocating
your missing a tooth on a large round gear in the gearbox.
when the gear on the engine rotates into the position where the little engine gear spins because there is no tooth to come into contact with the engine runs but the gearbox doesnt spin, hence no reciprocation, but engine runs.
if you bump the blade it will start going again, but when you cut it will stop offasionally in mid cut. you can repair this but stop using it the engine gear will be destroyed otherwise
I have a dewalt dw303 that you can use for parts, I need a new trigger or something the motor is dead and I found a new saw. go to craigslist.org, rochester ny tools section and look for dewalt dw303 that is my listing. for ten bucks ill sell you all the gears you need. i think it is close to the same model, i am sure it is the same gearbox.
try opening your gearbox, im positive that is what is wrong.
Posted on Apr 23, 2009
rowdy45176
  • 2176 Answers
SOURCE: lubrication and maintenance reciprocal saw DeWalt
Before you attempt any of this I would recommend going to Dewaltservicenet.com and see what the inside of this tool looks like. It appears that you need to remove part of the front gearcase to get into the lube. The back e.g. brushes is not that big of a deal. If there is a Service Center near you they have a Max repair rate that they will fix anything on this saw at a preset firm price and if it is less that is what they would charge.
Posted on May 18, 2009
  • 39 Answers
SOURCE: replacing blade assembly on a dewalt 18v Reciprocating Saw Sawzall
Remove the foot, remove the boot (and yellow lever), pull shaft out all the way (so you have more room to work with), remove the spring clip from the clamp block, remove the lever and ball, the clamp block will then slide off once the wire clip that wraps around it is removed.
Posted on Apr 24, 2012
How to find a trigger switch for a 305 DW Dewalt reciprocating saw
Hello, Frank -
Do you mean a Dewalt DWE305 model reciprocating saw? I do not find any model 305 DW for a Dewalt saw of any kind.
You can find the switch replacement to order here:
https://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DWE305&selectedType=26680
It is item #7.
Best wishes.
Apr 07, 2018 | Dewalt Saws
How to change a dewalt DW317 jigsaw Reciprocating Shaft
You will need to remove the blade holder then the 4 screws that hold the front cover on. You can go to DeWalt's service site using the link below and view or print a parts diagram which will help.
DEWALT ServiceNet
May 24, 2014 | Dewalt DW303 Heavy Duty 65 Amp...
My Dewalt DW938 battery powered reciprocating saw is eratic as to the reciprocating motion. The motor always turns when the trigger is depressed but the reciprocating action either doesn't start o
sounds like you have a gear problem, I suggest going to dewaltservicenet.com and typing in yoru model number so you can download a schematic for this tool. you have a problem in the gearcase area.
Feb 05, 2012 | Saws
How do I get a operating manual for a DeWalt DC385 Reciprocation saw
you can download the operators manual from this site
http://servicenet.dewalt.com/Products/Detail?productNumber=DC385B#
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 09, 2011 | Dewalt Dc385 Reciprocating Saw 18v Tool...
I have a Dewalt DC385 Reciprocating saw, when I hold it with the blade down or level the saw will not work but when I have the blade pointed upwards it works fine. I don't think it is the trigger...
I would look at the battery contacts first for burnt/discolored contact, if so clean with something like a pencil eraser, look at the contacts on the tool also. If these are acceptable then I would think a loose wire inside the handle area is causing. Before disassembly hold tool level and GENTLY tap with a soft hammer to see if you can get it to work and that would be a first indication of a bad connection
May 23, 2011 | Dewalt Dc385 Reciprocating Saw 18v Tool...
Can I use a dewalt 18 volt dc9098 battery on the dc385 Saw?
If you have the handle disigned for the lithium battery becareful using the 9096 battery as it moves in the handle a lot and can hit the terminal on the switch wrong and bend it or break it. Also it will get a lot of vibration when running and because it doen't have the support that it needs for a 9096 it wiill likely brak a contact on the switch eventually. the factory does say they work in any tool however.
Feb 14, 2011 | Dewalt 18v Battery Reciprocating Saw Dc385...
Is the Dewalt dw310 multi purpose saw available in 110 volts
  • Help Instructions, Repair Guides, Manuals & Troubleshooting sacore:green.gif Dewalt DW310K Heavy Duty Reciprocating Saw Kit... Is the Dewalt dw310 multi purpose saw available in 110 volts - posted in Reciprocating Saws ...
    www.fixya.com/troubleshoot
  • Jan 14, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
    Can I use a 18 volt XRP battery in the DeWalt DW938 Reciprocating saw?
    Yes. Dewalt says the 18volt XRP battery is compatible with all Dewalt 18volt tools
    Have a great day.
    Dec 29, 2010 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
    How do you remove the insulator boot on a Dewalt DW311 reciprocating saw?
    Hi.
    You need to do it carefully so you don't tear it... but it will just pel back and slide off...
    heatman101
    Jun 13, 2010 | Dewalt 11.8 amp reciprocating saw kit
    What is the problem when a dewalt reciprocating saw (cordless) losses power
    I am assuming you are refuring to the battery life. To be honest with you it is not a new problem. The Sawzall uses more power than the battery can store, so there don't last.
    If this is a new problem for you that you are noticing less power with fresh batteries., They could be bad batteries. Barrow someones, if you can and see.
    I hope this helps you. Please let me know if you have any further questions or if that this did help you.
    Aug 09, 2009 | Dewalt DC385B 18v. Cordless Bare...
    Saws Logo
    272 people viewed this question
    Top Dewalt Saws Experts
    JOHN LAPIER
    ken skalski
    Are you a Dewalt Saw Expert? Answer questions, earn points and help others
