Question about LG Refrigerators
My LG refrigerator is reporting error ER CO and it immediately stops working.
BFixed
  • 104 Answers
SOURCE: Error code ER FF
The error indicates the freezer fan is not functioning properly. The fan supplies cold air to the refrigerator that is why it seems warmer.
The fan may be frozen, try unplugging it for a few hours to let it thaw. Also check to see if something may have gotten into the vent holes in the freezer that could be blocking the fan from turning.
Posted on Mar 11, 2008
  • 110 Answers
SOURCE: LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Jun 13, 2008
  • 1122 Answers
SOURCE: where is this fuse located on the LG refrigerator is displaying a ER DH code error
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Posted on Jul 07, 2008
SOURCE: LG refrigerator error code
Had the same problem + a weird noise, which turned out to be ice build up on the blower fan. Unplugged overnight and then opened the lower back panel. There is a small fan that blows over some small coils at the bottom of the box. There is also a drip pan that should be "full" of water. I sponged out the drip pan, put the panel back on and then plugged back in. Works great.
Posted on Nov 04, 2008
SOURCE: LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Posted on Apr 08, 2009
LG lfx31945 REFIGERATOR...FREEZER NOT COOLING. ER FF CODE
LG Help Library: Error Codes - Refrigerator ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library
  1. Cached
  2. Similar
Feb 26, 2018 - FF Error Code. A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup. ... If you notice frost buildup along the walls of the freezer compartment, the leveling and door alignment of the refrigerator will need to be checked.
SOLVED: Error Code ER FF - Fixya
www.fixya.com/support/t121701-error_code_er_ff
  1. Cached
  2. Similar
Oct 18, 2006 - Error Code ER FF Our refrigerator is 1 year & 1 week old. A few days ago it started making a noise that sounded - LG LRBC22544 Bottom Freezer question. SOLVED: Error codes Er rF 10 posts 14 Nov 2013 Lg lfx31925st 00 code er ff 10 posts 21 Sep 2013 SOLVED: How Do You Repair An lg lfx31925st error ... 11 posts 16 Nov 2012 SOLVED: LG refrigerator lrsc26944tt error code ER FF 11 posts 25 Jan 2009 More results from www.fixya.com
FIXED LG refrigerator error code Er FF - ApplianceBlog
https://www.applianceblog.com/mainforums/.../8302-LG-refrigerator-error-code-Er-F...
  1. Cached
  2. Similar
Mar 31, 2007 - Hey guys, This LG has me stuck. I have run the smart board entirely through the diagnostic mode and it says everything is OK - hours later a code comes up "Er FF" Model: LRSC26922TT Serial: 407KRPV00464 I have had no luck finding any useful info on the web.... nothing but horror stories about LG. FIXED LG Refrigerator LFXS32726 - Error Code E rF 3 Aug 2016 LG LFX31925 drain iced up (ER FF code) - How to remove freezer ... 24 May 2016 FIXED LG LFX31925ST Giving error code ER RF 3 Sep 2013 Kenmore elite refrigerator error code er FF 3 Mar 2013 More results from www.applianceblog.com
LG REFRIGERATOR REPAIR. HOW TO REPLACE FREEZER FAN. FF ...
9k=? 4:42 https://www.youtube.com/watch?v=Yiifd2sTrZI
  1. Similar
Jan 3, 2013 - Uploaded by SOCALAPPLIANCE LG Refrigerator repair. FF error code / ee ff . Bad freezer fan. Bad evaporator fan. How to repair an LG ...
Mar 22, 2018 | LG Refrigerators
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
What does message Er IF mean?
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan that controls the unit's ice production. If this problem occurs because of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to thaw may fix the issue. Call customer service if that doesn't work.
Oct 12, 2012 | LG Refrigerators
What does Er CO message on the LG fridge mean?
The LG Refrigerators are designed in such a way that the owner is alerted of possible problems with the product and allow easy detection and repair by repairmen. These LG refrigerators have common error that can be easily remedied by the user.
"Er CO" on your display screen means that there is an error in the event of a short or other malfunction associated with communication between the main circuit board and the display.
To resolve this problem, System reset is an option and mostly likely customer service should be contacted to provided a permanent solution.
thank you.
Sep 09, 2011 | Kitchen Appliances - Others
Not working, ER and CO in spots for temp. French
ER CO is an indication of a communication error between the display board and the main board. Has this unit had a board replaced recently? If so, one of the multi pin plugs may have not gotten connected firmly, or an incorrect board may have been installed. The problem has nothing to do with the dust.
Feb 28, 2011 | LG LFX25960ST Stainless Steel French Door...
Cheats sf
We don't understand what you exactly mean. If it means a eror code, please find below the error codes and its solutions.
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error Er-Ff- Freezer fan fault. Write again if you're not satisfied with this answer.Thanks.
Feb 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The panel control going shows Er in temp display
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
Aug 21, 2009 | LG LRSC-26922 Side by Side Refrigerator
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
Jul 07, 2008 | LG LRFC25750 Refrigerator French Door
Jun 13, 2008 | Refrigerators
LG LRFD25850ST gives ER CO code on door
There is a communications error between the control board and the display board.  Check the connector located on the top hinge cover.  Remove the hinge cover and check to make sure the connector is tightly secured.
Apr 12, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
