Question about Kyocera Office Equipment & Supplies
Kyocera task alfa 2551ci machine show white screen and frozen when start up. the welcome message does not can I solve this.Any idea ?
2 Suggested Answers
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
I need a keyosara task alfa 180 services ook
I think the Kyocera copier service manual you are looking for is available for download at
Apr 19, 2014 | Kyocera Office Equipment & Supplies
Clean slit glass
the slit glass is dirty. clean it. see if there is a secondary slit glass (depends on the adf). you can turn off the message in service mode.
Apr 17, 2013 | Kyocera Task Alfa / Copystar 400ci / 500ci...
Call service c
your fuser tripped an error flag. Try power cycling the machine. If that does not work then press the button to check job status and enter 10871087. You might be able to enter that code from the copy screen. In any case lets continue, you enter that code and then screen changes. You then enter 906... That is a general reset. You could also try 163 that is a fuser reset. If neither one works then you need a new fuser unit
in many cases, the cause of fuser failure is not using oem toner.
kyocera task alfa 180 oem toner
Sep 13, 2012 | Kyocera TASKalfa 180 Copier
C9050 in km8030
can i fill the toner in the cartridge TK439 of kyocera task alfa 180, where did i make the hole to cartridge, is there is need of ICchip.please help. which toner is advisable,and what will be the toner cost,
Feb 21, 2012 | Kyocera Office Equipment & Supplies
Master reset code Taskalfa 180
Kyocera mita task alfa 1800..error code 0800
Jan 18, 2012 | Kyocera TASKalfa 180 Copier
I have a fs c2126 kyocera printer it gives me c4600 error code
Good afternoon,
Please can someone tell me what is the error C4600 printer kyocera TASKalfa 2551ci?
How can I solve it?
Jul 20, 2011 | Kyocera FS-1118MFP Laser Printer
108 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
