Question about Nokia Cell Phones
I can't connect my 5130c-2 with my pc Even through USB as well as Bluetooth Plz help me
How to connect to the pc
There are two ways to connect from phone to pc .Firstly we can connect via bluetooth,but usb is the simplest.Here some setting will be done by you in your phone Open Menu>>Setting>>Connectivity>>Usb data cable>>Ask on conn....after you have selected "ask on conn" connect the phone via usb to your pc and select PC Suite when a message prompt.Before you proceed download and install Nokia PC Suite 7.0.8.2 - Free software downloads and software reviews - CNET Download.com.Good luck
Feb 09, 2012 | Nokia 5130 XpressMusic Red Unlocked Import...
I m using c3 nokia i m not purchasing the usb so plz help me out to transfer the data from cell to pc and vice versa by using bluetooth,
To connect your phone using bluettoth, you need the following things.
1) Nokia PC Suite
2)Bluetooth dongle with the driver installed.
Things to be done on pc side :
1. give your host bluetooth name
2. find BTCOM port
My Computer->My Bluetooth Places->right click my device->Local Services->Bluetooth Serial Port
Things to do on phone side :
1. give your phone bt name
then install pc suite and modem tool (if necessary)
restart computer
For pairing :
1. add device
host: go to My Bluetooth Places->Add new connection
phone: go to bluetooth, choose Paired Devices->add
2. provide passkey (4-digit, 0-9 only) on both
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Nov 28, 2010 | Computers & Internet
How to connect nokia 5130c to my pc.
download Nokia PC suite to your PC
to download the correct version for your device click here
use the Micro USB cable that came with the device if you have one.
Install the Pc suite to your computer and follow the onscreen instruction once its done installing the software it will ask you to plug in your device.
if you dont have any cable you can use Bluetooth to sync your device to your PC and vice versa
hope this help
Sep 08, 2010 | Nokia 5130 Cellular Phone
Forget my mobile security code(Nokia 5130c XM)...Plz Help
4745066750 try this. it is your master code, hope it helps
Apr 16, 2010 | Nokia 5310 Cellular Phone
Full phone memory even though its not full it affects the music library .my nokia 5130c phone shows that the phone memory is full but ithas much memory to messages and other files and even affects the...
please help me!!!!
my nokia 5130c-2 is showing not enough phone memory!!!
when i check how much memory i have left on the phone memory it show's less memory.Basically nokia 5130 have about 32MB memory but it shows about 6 To 7MB memory. All the files that i have recieved through bluetooth is stored in the memory card ...
whenever i change a theme the phone memory gets reduced...
i'm not able to update my music library because of this...
pz plz plz plz help me!!!!
Jul 02, 2009 | Nokia 5130 Cellular Phone
Full phone memory even though it's not full..
these problem needs a complete restore factory settings.i had these kind of prob with my 6085 phone and the phone memory corrupted..it occured when u removed ur mem card while using some files or application in it.
Jun 24, 2009 | Nokia 5130 Cellular Phone
How can i connect my nokia 5130 c 2 to my pc
Iam unable to conect my 5130c 2 to pc through data cable as the driver cd not supplied with the pack
Jun 22, 2009 | Nokia 5130 Cellular Phone
I have nokia xpress music 5130 and it gives me
I myself own this awesome music phone.
Find the answers below:
1) As it shows less internal memory, it seems that you have transfered some data like mp3, video clips through bluetooth to this phone and it was saved in the recieved folder which autmatically saves in phone memory. Try saving the data to memory card and you will get the phone memory free.
2) Check the above reason for this same issue.
3) You need to select proper connectivity mode under settings of this phone. Go to settings and then open connectivity folder. Here select the connection mode.
Make sure to install the latest PC suite software on the computer. This can be downloaded from the NOKIA website.
Regards
Anand
Rate it, if it helps.
Jun 11, 2009 | Nokia 5130 Cellular Phone
Cell Phones Logo
52 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
