Question about Acer Office Equipment & Supplies
ACER PROJECTOR 1165 TO RESET PASSWORD DEATIL PLESE
We have an Acer P3250 projector that keeps prompting for a password upon start-up. However, when we enter the security password provided with the unit, it says it is "invalid".
Found an earlier suggestion on this site if you don't have the provided password and also already tried 1234.
1. Turn on the projector 2. Press "Power > Left > Left > MENU" (Opens the system menu)
3. Choose "RD Menu"
4. Choose " EEPROM Restore" (the projector turn off and the power lamp blink red for about 1 minut. Then it stops)
5. Turn on the projector again and it should work again
Acer P3250 will not acccept password
Mar 27, 2015 | Acer P3250 DLP Projector
I waynt to remove password projector
According to the manual listed below you can :
(1) Enter the OSD menu.
(2) To execute "Reset" function.
This resets all the user settings to default.
Press "Play" to change the "Administrator Password".
The factory default of "Administrator Password" is "1234".
Service Manual link
Download manual
Mar 12, 2015 | Acer P3250 Multimedia Projector
Acer P1265 projector asking for password
Security
This projector provides a useful security function for the
administrator to manage usage of the projector .
Press to change the "Security" setting. If the security function
is enabled, your must enter the "Administrator Password" first
before changing the security settings.
• Select "On" to enable the security function. The user has to
enter a password to operate the projector. Please refer to the
"User Password" section for details.
• If "Off" is selected, then the user can turn on the projector
without password.
Feb 06, 2012 | Acer P1265 DLP Projector
My acer dlp projector P3150 is locked with password. i cannot remember i set my own password. may i know how to unlock it? i tried 1234 and 000000 but they did not work.
you can try to reset the projector back to its factory default setting, go to menu then scroll down look for the reset to factory default
Aug 07, 2011 | Computers & Internet
Restore Acer Aspire ONE D150-1165 Netbook
On help and support menu, type restore system. You will get an option to what date your OS will restored. Make sure you decide the correct date ( when the OS is still working fine). Key in the date ( or choose the preset date) the enter. Wait for process done completely. Your OS should be restored now.
Jun 28, 2011 | Acer Aspire One D150-1587 Netbook
Acer projector P3150 locked with passwd
Read some Acer manual and it says:
The "Administrator Password" can be used in both the "Enter
Administrator Password" and "Enter Password" dialog boxes.
• Press "Play" to change the "Administrator Password".
• The factory default of "Administrator Password" is "1234".
If you forgot your administrator password, do the following to
retrieve the administrator password:
• An unique 6-digit "Universal Password" which is printed on
the Security Card (please check accessory in the box). This
unique password is the number which will be accepted by
projector anytime no matter what the Administrator
Password is.
• If losing this security card and number, please contact with an
Acer service center.
Jan 28, 2010 | Acer P3250 DLP Projector
Acer P3250 will not acccept password...
I found a solution that worked for me:
3. Choose "RD Menu"
Sep 15, 2009 | Acer Office Equipment & Supplies
To remove password
If you have forgotten your password, then please do the following, to retrieve the administrator password:
A unique 6 digit "universal password" which is printed on the security card ( must have come along with the projector) The unique password will be accepted by the projector no matter what administrator password you had put in earleir.
In case you have lost the security card and the unique password , you will need to contact the Acer service center in you area.
Best of luck
Mar 11, 2009 | Acer Office Equipment & Supplies
57 people viewed this question
Top Acer Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
