Question about Dishwashers
How can I change the inlet water flexible braided line without removing the dishwasher from the cabinet. I have a Maytag model # MDBH945AWQ. Thanks, Luis Gutie
jsrock516
  • 5911 Answers
SOURCE: noisy kitchenaid dishwasher during filling
Fill valve replacement should be fairly simple. Most dishwashers are constructed in a similar manner, so although these steps are generic, it should lead you in the right direction: 1. Remove the lower kick panel right below the dishwasher door. The fill valve should be located in the front of the dishwasher on the left hand side. 2. Turn off the water supply line. 3. Turn off the circuit breaker to the dishwasher or unplug the unit as necessary to secure power. 4. Carefully remove the two wire connectors going to the fill valve solenoid. These wires are delicate, so be careful with them. 5. Leave the fill valve attached to the mounting plate in order to loosen the supply line. Once you have the supply line loosened you can remove the valve from the mounting plate by removing either one or two screws. 6. With the supply line disconnected, wires removed and the valve removed from the mounting plate, you can now remove the secondary water line that goes into the wash tub. It is usually behind the valve and easier to access if you can pull the valve out far enough the reach it. 7. Make sure you put teflon on all your threads BEFORE you re-install. 8. Installation is in the reverse of what I just explained to you. You should not have to remove the dishwasher from under the counter, but you can if it makes access easier. It's that easy. Just make sure you check your water lines for leaks BEFORE re-installing the kick plate. And, make sure you reconnect the wires properly. Good luck. I hope this helps you.
Posted on Jul 10, 2007
  • 1314 Answers
SOURCE: Connecting the hot water line to a new dishwasher.
use teflon tape on the elbow if you did the back it off put some more on it and stop when its snugged facing the right direction now ive torqued them things pretty tight my self they don't strip that easy
Posted on Feb 16, 2008
  • 131 Answers
SOURCE: Maytag Performa dishwasher
Check the float switch.
Posted on Mar 10, 2008
jsrock516
  • 5911 Answers
SOURCE: water inlet valve Kenmore dishwasher
Okay handy Mike,
First of all, is this a new dishwasher? Or, is it a used one? The reason I ask is because there should be a warranty with a new appliance and you should not have to worry, or have to pay for, any repairs.
The problem you are experiencing could very well be a water inlet valve problem (good assessment), but may also be something more simple. The dishwasher has a float inside the tub that is supposed to shut the water off, when it reaches the appropriate fill level. Check the float to make sure it moves up and down and that you can hear the switch "clicking". Sometimes small items get stuck under the float and will keep in the up (or shut off position).
For some helpful part locator drawings refer to searspartsdirect.com and type in your model number. An illustration of the water inlet valve can be found under the "Frame" heading in the next page as item number 24 (part number 154195301). The float and float switch can be found under the "Tub" heading as items number 13 (part number 154144301) and 24 (part number 5300809863), respectively.
If you require further assistance, please let me know. I hope its something simple and you don't require parts. But, if you do, you know where you can get them. If you do not wish to order on line, use the part numbers provided and go to your nearest appliance parts retailer. I hope this helps you. Good Luck.
Jeff
Posted on Jul 09, 2008
  • 59 Answers
SOURCE: Dishwasher LDF7920ST. Connection to water inlet leaks
if it just started the water inlet is probably defective. this can be obtained at your local hdwre. store. be carefull these oarta are brass and are really soft. pull the dish washer out and tip it up or remove it, dont try to change it where it is.
Posted on Jan 03, 2010
Kenmore dishwasher water inlet valve replacement
Turn off power to dishwasher at the breaker or fuse panel.Turn off water supply usually found under sink. Remove the front kick panel and remove water supply line from the valve,remove clamp to hose on dishwasher and remove hose. Remove electrical connectors from the inlet valve and remove screws holding valve to cabinet . Reverse steps to install. Slowly turn on water and listen and look for leaks if all is well turn on the power and start washing.
Mar 21, 2014 | Kenmore Elite 24" Built-In Dishwasher with...
Bosch SHU4006 UC/06 Dishwasher will not fill with water and timer does not advance. Voltage to Water Valve Solenoid does not toggle when timer knob is manually advanced through all cycles.
If you have power to water valve when it is supposed to fill yet doesn't the water valve is bad, as long as their is a good water supply to the valve. Sometimes espically if it has one of those flexible stainless steel braided hoses something in cabinet could have pinched it,
Good luck,i hope this helps
Gene
Aug 01, 2011 | Bosch SHU4006 Dishwasher
Latch handle broken
Hi and welcome to FixYa, I am Kelly.
Your parts are here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177084 See item 3
This comes apart by removing the screws from the inside of the door. Control panel first. Then door skin if necessary. Make sure to check the condition of the door striker also. (part that latch locks on to.)
Thanks for choosing FixYa,
Kelly
Jun 22, 2011 | Maytag MDBH945AWW / MDBH945AWQ /...
How do I find and remove the water inlet valve in a Maytag MDB-9 dishwasher?
CLICK HERE for a representation of the part in question.
CLICK HERE for an expanded parts diagram (#1)
1. Shut off the water and remove the lower access/kick panels.
2. Then disconnect the two wires from the inlet valve terminals - note which one goes to which terminal
3. Using an open end wrench loosen and disconnect the water supply line.
4. Remove the two screws securing the valve assembly to the inside wall of the dishwasher
5. Loosen the clamp on the water outlet line and slide off the hose.
Installation is pretty much the same in reverse.
Sometimes the valve assembly comes with the wire terminals oriented in a different direction than what you may find when you take yours off. If it won't work for you, remove the four screws that hold the electrical side of the inlet valve and rotate it to the needed position.
Make sure when putting it back together that you tighten the screws evenly to prevent leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2010 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag Dishwasher-MDBH945AWW
About the only things that move in the cabinet other than the water pump is the spray arms. The lower arm should be screwed down fairly tightly (plastic screw), but the upper arm is held in place with a plastic friction plug--it tends to wobble more. Spin both arms by hand to see if either hits something (have the drawers in). The lower arm has metal clips on the ends which may be coming loose. They are just clipped onto the arm edges. Hope this helps!
Apr 06, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
I need details on how to install Maytag built in dishwasher
Hello Ted, Without the exact model number, it is difficult to provide the correct installation instructions for your specific Maytag dishwasher.
I can provide you with a link to the Maytag site where you can enter in your model number and download an owners manual and installation instructions/guide that will provide you with the step-by-step needed to properly install your dishwasher.
http://www.maytag.com/support/manuals_literature.jsp
The installation instructions will provide the proper wiring, water supply inlet plumbing and connection of the water discharge line, as well as all of the dimensions needed for clearances for the countertop and cabinets.
If you're trying to install an older dishwasher, you can also give them a call at 1-800-344-1274 and have your complete model number available, so they can provide you the correct manuals and instructions.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Dishwashers
My Maytag mdb 7 dishwasher stopped working on the same day that a Plumber came to our house to fix our toilet. He says he didn't turn off the water anywhere in the house, other than the valve beside the...
If he indeed only accessed the toiled shut off valve, then that would not affect the dishwasher.
Even if dirt/sediment got into the line to the washer somehow, it should be able to be cleared at the inlet valve to the washer.
As to you needing to replace the washer, one would need to determine what the problem is first. It could be a very simple and cheap repair.
If he indeed only shut off the toilet valve, then yes, it would be a coincidence that the washer went out the same day.
If you are on city water, then it is possible that if there is construction nearby or anything that would introduce sediment into the line upline from you, that it could have contaminated the washer.
If your toilet was having problems with water flow as well (thus your reason for calling a plumber) then I would strongly suspect that this is the case.
It is possible that both issues were caused by sediment/dirt from your city water source.
Sep 27, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
Loud noise at end of Draining
If your dishwasher seems noisy, check these:
1. Water-inlet valve
2. Motor
3 Heater fan
4. Pump
Water-inlet valve
An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor
If it's the motor that's noisy, either of these may be the "culprit:"
As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan
If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump
Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
good luck
thanks for using FixYa
Jan 28, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
I need to unplug and move a built-in Maytag dishwasher
Follow these steps:
1. Locate the electrical service breaker for your appliance and turn it off at the breaker panel. If it is plugged in by a serivce outlet, unplug the unit.
2. Turn off the water source under the sink.
3. Disconnect the drain line under the sink.
4. Remove the lower panel under the dishwasher door.
5. Locate the small electrical junction box under the dishwasher and disconnect the wires leads. Remember, standard household wiring is as follows: BLACK (HOT - 110-120VAC), WHITE (NEUTRAL - 0VAC, GREEN (or bare copper) is GROUND. Make sure you reconnect the wires in this fashion with wire lug nuts. If you have a local outlet plug you may leave the wiring instact.
6. Locate the fill valve (Usually on the left hand side of the dishwasher). This is where the water supply line connects. Disconnect the water supply line from the fill valve.
7. The dishwasher should have a couple of mounting screws located where the top of the dishwasher cabinet meets the underside of the cabinet.
8. With everything removed, the dishwasher should now be free and slide out from under the cabinet.
Let me know if you have further questions. I hope this helps you.
NOTE: You can also remove the water supply line at the fitting under the sink if it makes things easier.
Jul 24, 2008 | Maytag Dishwashers
Dishwashers Logo
Top Dishwashers Experts
