Question about Avanti Top Load Washer W797
Avanti W797: Tub won't spin or water does not empty.
My Avanti W797 is about 2.5 yrs old. It will not perform the spin cycle nor will the water empty.
  • 1 more comment
  • breeangel10 Sep 06, 2008
    where is the water pump?
  • merisa4 Nov 08, 2008
    Hi, Themachine won't drain, rinse and spin. The problem comes from the water pump but how to access it if everything is glue together? Where is that magnet, how it looks like?
    tks a lot
  • Anonymous Mar 24, 2014
    Can i fix it with tape?
  • 3 Answers
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Posted on Apr 20, 2008
Cold water inlet never stop. whenever I turn on the tap ..the water from cold water inlet will not stop ,even the mashine is full....
Posted on May 26, 2008
The water pump is underneath of the washer, pull out the cover against noise and the water pump is right there; get a screw driver and take out.
Posted on Dec 14, 2011
My avanti w797 will drain water but won't spin to wash the clothes. It only spin at last 3 minutes. Please help.
Posted on Feb 03, 2016
I took out the water pump and found a paper clip in it which was keeping the pump impeller from spinning! I took it out and reinstalled the pump and now it works fine.
  • Sarah Dobrosky Nov 15, 2011
    Where is the water pump located? I'm having the same problem with the water still in the machine. I'm nervous to disconnect/do anything without knowing exactly what I'm doing.
Washing machine works up to the spin cycle, it does not spin it does however empty the water. this is a roper brand top load machine about 5 yrs old.
Lid switch. A safety mechanism used to make sure lid is closed in spin cycle. You can bypass this switch by placing the wires that go to switch together. DO NOT do this if you have children or do not want to remove that safety feature some require because they dont know better than to open a washer in spin cycle. :)
Jul 07, 2010 | Roper RAS8445KQ Top Load Washer
Admiral washing machine will fill won't spin
You have possibly 2 senarios there. One is possibly your capacitor is defective and two if cap is good, your main motor is faulty.
May 20, 2010 | Admiral AW22 Top Load Washer
Dryer not spinning
hi, if its not spinning try the motor brushes, will be well worn if 5 yrs old or over. not too hard to replace or expensive if carbons only..please leave feedback.
Apr 07, 2010 | Dryers
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Dial doesn't advance to next cycle
if u can advance it manually and it works u need a timer if not probably a lidswitch
Mar 27, 2009 | Maytag Washing Machines
No spin or agitation on washing machine
check the coupler it is the plastic and rubber piece that is in between the motor and the transmission
Dec 30, 2008 | Whirlpool Washing Machines
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
Avanti Top Load Washer W797 Logo
2,608 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
